Bf F6 Typhoon 487Kw 6Boost Forced Performance
Bolton
  • Member For: 16y 6m 2d
Does fpt,sDyno reading too high you think??
Nope most cars that have gone from there to dyno comps are always pretty close and vice versa.
As for running mph that it shows on the dyno pretty much, with about 500kw mine ran 142 mph and a hand full of other running abit over 400/440kw about 132mph. It's easy to make a figure on the dyno and the car play nice but take it to the track and a poor std zf that's fine with a couple of dyno pulls but put high load behind it tends to not play nice in the top end which can cause it to loose a few mph.
I'm pretty sure this car went 10.9 @132 on the old tune (411) so that's right in the ball park.
Jet it always seems to be you instigating, just because you haven't seen it done doesn't mean jack sh1t. Single pump and 487kw and still safe afr levels what more do ya need to see. yes timing levels are set appropriately for e85 to make these figures if your tuner or other tuners arent comfortable pushing to those levels to get the desired results well that's completely up to them. Jamie's been playing with e85 since it first became readily available so has plenty of experience using it and knows what it's safely capable of doing.
This car has a new owner as of about a week ago so good luck to him and he will be racing it soon enough so will be good to see what type of results they get with the new tune.
  • Like 6
