Bf F6 Typhoon 487Kw 6Boost Forced Performance
Bolton
  • Member For: 19y 4m 5d
Airflow and AFR will dictate fuel requirements....getting the most out of it via Ignition timing etc will dictate what power can be made. Must be advanced to the $hithouse to pull those numbers. It is what it is I guess!!
  • Member For: 16y 7m 23d
There's so many ??? To be asked. If it runs 138mph ill believe it then.
Till then, congrats on 450.
  • Like 3
  • RNS10S
  • Member For: 18y 2m 27d
OP will be taking it to the drags, MPH will dictate what power it has.
Miguels F6 had 488 and went 138 MPH, this should be around that as stated by Bolton
I would not have thought that a 35/40 could make that power, especially when guys are making around 450 with a GTX and if it did I wouldn't have thought it would be possible on 1 044.
Well done.
  • Member For: 13y 3m 19d
Hi guys I'm pretty sure Jamie said there was 14deg timing. And that there was more in it. Like I said he was quite shocked aswell With the power. Just keep the negatives to yourselves I didn't post it up show off or big note as stated by I <3 donkeys " it is what it is" will post my slip when I run it next! Cheers
  • Like 3
I'm sure Jamie has done enough cars to be confident with figures. I would think it would have ALOT more than 14 degrees to make that sort of power....but that would be on the money for your pump tune. For example the last pump tune I did with very similar mods (but with a nizpro stage 1 cooler and plenum) went just under 400 with ~10 degrees timing at peak power.....so it's on the money there. I reckon Jamie has just gone happy with timing on e85 and the engine seems to have loved it :-)
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 5m 12d
I love all of this so much sa win right here
One o44 and stock turbo doing 480 wheres dale when u need him
Good work op
