Mixing Engine Oil
xrBlitz
  • Here since the start...
  • Member For: 21y 9m 8d
5 is not too light. 5 is in fact thicker than 40, as this is when the oil is cold, and its viscosity changes as it goes to 40 which is at operating temp.
So a 5w40 is fine a 0w40 is fine. All it means is that the starting viscosity of the oil is closer to what the engine requires at operating temp.
You don't say!
Makes me wonder why N/A engines use 10-40 and the T uses 15-40... Meh, never mind I'm sure you know best.
  • Member For: 16y 2m 11d
Wouldn't 10w-60 be a bit much for the fords?
Mine loves 10w60. Very important to let the car warm up properly though. I drive 20 Ks before I give it a good thrashing.
Are you guys going off the temp gauge or an aftermarket oil temp gauge?
I've found that the coolant gets up to temp much quicker than the oil.
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 1m 17d
Oil temp gauge for me. FWIW Nulon 10w40 and Edge 0w40 would go up to and past 120c when thrashing hard for awhile, but Edge 10w60 never went past 115c. If I put an oil cooler on ill go back to Edge 0w40
  • Member For: 15y 11m 16d
So Edge 10w60 with a 30min warm up before giving it a squirt, or Edge 0w40 with oil cooler if your thrashing it for a long duration, what if you only boost off the line at a set of lights once in a blue moon, would Edge 0w40 be fine to use? And for everyday driving?
Also, I ended up buying Transmax Z for the t56, I had to buy 2x4Lts bottle at $75 each as they didn't have any 1Lt or 2Lt bottle at any of the local ripco or superheap, so my question is, what sort of shelf life does an open bottle of this stuff last for, I do around 10k km a year in the car so I probably won't need to change it for 2 or so years.
