PSI O6T Donating Members 440 Member For: 12y 5m 24d Gender: Male Location: sydney Posted 25/09/12 03:03 AM Author Share Posted 25/09/12 03:03 AM the rapid cooling looks a lot shorter in comparison to the process west cold sidehttp://www.rapidsystems.com.au/index.php?p=1_26is there any headlight mods to do with the rapid piping ? Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 1m 18d Gender: Male Location: Christchurch, New Zealand Posted 25/09/12 03:12 AM Share Posted 25/09/12 03:12 AM Sounds like your talking about the coldside pipe from the cooler to the intake manifold. Some of them retain the stock crossover so run the pipe from the aftermarket cooler back infront of the engine to the crossover whereas others come through the stock airbox area and straight to the manifold. Link to comment Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 5m 24d Gender: Male Location: sydney Posted 25/09/12 03:33 AM Author Share Posted 25/09/12 03:33 AM (edited) just spoke to Chris from rapid, he said as long as you put the silicon joiner to the far right corner it clears the headlight with no issues. also there is no issues with clearance from the throttle body if installed correctly . im looking at a v3 kit for $1649 includes k & n filter.V3.0 $1649Intercooler, cold side piping , Under battery Intake& Hotside Piping Edited 25/09/12 03:33 AM by tresurehunt Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 10m 15d Gender: Male Location: Sydney Posted 25/09/12 10:01 AM Share Posted 25/09/12 10:01 AM may need to modify the parker globe connector but I could be wrong.. Link to comment Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 5m 24d Gender: Male Location: sydney Posted 30/09/12 07:07 AM Author Share Posted 30/09/12 07:07 AM ok now looking at an under battery air intake kit, I thought I saw on here somewhere that they make their own ?doesnt look that hard.... Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 10m 15d Gender: Male Location: Sydney Posted 30/09/12 07:52 AM Share Posted 30/09/12 07:52 AM Dont go the around the world cold side dude.. look up orangeute888 on the falcon forum and ask him if he can make you a tb relocation pipe inc. that pipe that goes on from the relocated tb toward the headlight. then just get the next joiner + pipe and next joiner from rapid... all the cold side will be 3".You would need to just extend your tb cables and still get your hot side piping, rapids hot side seems to be reasonably priced too..Personally I went this way about it and saved a fair bit of cash and ended up with wat I believe to be the next best thing from a plenum.You would still need to get a cooler though dont go pov here.I made my own intake which consisted of 2x 45degree bends, 90 degree bend and about 400mm of 3" alloy pipe. I had to remove the back leg of the battery platform though and drill a 90mm hole in front of the battery section there and fit a pod in the front bar. The whistle is freakin awesome.TBH this way does work and is cheap and very effective but sooner rather than later I'll be pulling the pod out of the front bar area... only due to the fact that you get paranoid driving thru puddles other than that in all seriousness its been gr8. Link to comment Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 5m 24d Gender: Male Location: sydney Posted 30/09/12 08:30 AM Author Share Posted 30/09/12 08:30 AM I was talking about off the front of the turbo..... under battery kit Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 10m 15d Gender: Male Location: Sydney Posted 30/09/12 08:31 AM Share Posted 30/09/12 08:31 AM I know Link to comment Share on other sites More sharing options...
cjsxrt Donating Members 145 Member For: 16y 2m 23d Posted 30/09/12 09:29 AM Share Posted 30/09/12 09:29 AM There's a pw under battery on eBay for $200 Link to comment Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 5m 24d Gender: Male Location: sydney Posted 30/09/12 10:32 AM Author Share Posted 30/09/12 10:32 AM sorry cruzin I just read your full post, does this effect drivability when you relocate tb ? Link to comment Share on other sites More sharing options...
