  • Member For: 19y 10m 30d
Guys,
I have a stock standard FG XR6T, and when the car comes on boost it doesn't have that typical high pitched whistle, the sound pitch is a bit off.(sort of sounds like a supercharger)
Took it to Ford the other day and they tightened a few of the exhaust manifold bolts, but turbo sounds the same, and they reckon the turbo noise is normal.
There turbo noise is easily heard in the cabin, and I just want to know if other FG XR6Ts, sound the same.
Also want to confirm that the slight back fire in between gear changes (auto)...is normal for the car also...apparently this is spark cut out?
https://www.fordxr6turbo.com/forum/topic/82015-fg-xr6-turbo-noise/
  • Forged Member
  • Member For: 18y 2m 11d
The noise is going to be rediculously hard for anyone to understand unless you can record it.
The farts in between gears is normal, yes it is spark cut :spoton:
Yeah I have actually heard allot of the R Spec, and GTI Golfs do it...but wasn't sure if this was normal for the FG's...Ok so we have confirmed the fart is normal, was worried the fart could possibly turn into a sh*tting of the pants scenario...lol...
As far as the turbo noise goes...I might have to take the car passed one of the reputable tuners on this website, and get them to have a listen.
  • Member For: 13y 7m 11d
One or several of your compressor blades might have small bends in them. A drop of water getting into the cold air intake is normally the culprit of this damage.
  • Skid Machine
  • Member For: 13y 10m 25d
I drove my GT-R for the 1st time Monday night and my turbo's seem to be making the same noise as you're describing. It's making me a bit nervous.
This XR6 Turbo has a bend in one of the turbine blades.. does this sound anything like the sound you're experiencing?
Edited by The Converted
  • Skid Machine
That does sound fairly similar. I guess that's what's wrong with mine.
Spark cut is sort of like a limiter to limit torque between gear changes.
