Choosing Injectors For Fg F6
TJS
  • Member For: 13y 4m 30d
Hi gang,
Every tuner I have spoken to either prefers a particular injector or drills out your existing ones when they give it a custom tune.
Does it matter? Should I just let them do what they advise? Or, if I can get good injectors cheap, will I save on a tune? Or will the tuner say nah mate dont use them.
I am looking for a mild tune to get me close to 350rwkw - nothing wild. They all say they can do that with just a tune and injectors.
Is there a minimum flow rate I should be looking for to get 350? What are your experiences with your choice of injectors (or your tuner's choice as it may have been..)?
Cheers,
TJS
  • Moar Powar Babeh
  • Member For: 19y 6m 15d
For my money ID's all the way. But you need to find out what your tuner prefers and is comfortable tuning.
Also be aware that many reputable tuners (IE Mick from Pitlane) will want to flow test second hand injectors before fitting to ensure thet are a good set so this will add to the cost.
  • Like 3
  • Member For: 19y 5m 16d
Hi gang,
Cheers,
TJS
KPM550cc / KPM1000cc / KPM2000cc
Availble online best pricing and delivered next day.
Guaranteed brand new match flowed +/- 1%
Full 100% Australia wide guarantee
http://www.kpmauto.com/tabid/223/CategoryID/17/List/0/Level/a/ProductID/232/Default.aspx?SortField=ProductName%2cProductName
  • Member For: 15y 6m 21d
Bosch, Xspurt, ID's... same same... KPM's are priced very well... I'd go 1000cc to give you some head room if you want to push further. Still have great idle and economy..... These are the best injectors I have had in my car..
But, always best to go with what your tuner recommends... No point turning up with injectors they have never used before...
  • Like 2
Thanks guys,
Is there a conversion from lbs to cc? One sounds like pressure, the other volume ?? And does anyone know what are the std ones are equal to in these measurements?
Cheers,
TJS
KPM recomendations for usable margins.
KPM550cc injectors up to 350fwkw form petrol and E85
KPM1000cc injectors up to 480fwkw for petrol and E85
KPM2000cc injectors up to 1000fwkw for petrol and E85
Idle quality on both injectors are perfect.
The applications are calculated on the following;
550cc Approx 480fwkw for the 4.0T engine
70-75% Duty Cycle for 98/95 Octane fuel
90% Duty Cycle for E85 Fuel
1000cc Approx 480fwkw for the 4.0T engine
2000cc Approx 1000fwkw for the 4.0T engine
75-80% Duty Cycle for 98.95 Octane Fuel
95% Duty Cycle for E85 Fuel
KPM can supply all scaling/characterisation data for every KPM Injector supplied. This removes any guess work and allows correct parameters to be input, to allow best tuning results.
Which of the three sizes do you recomend for max kw?
