  • Me
  • Member For: 18y 19d
Make sure you disconnect the vaccuum T peice at the back. Unplugging the plug on the firewall costs you KW's.
  • Member For: 12y 7m 10d
Yeah ill definitely do the one above the muffer. Just want to make sure I remove/block the right one...
  • Member For: 21y 8m 10d
You will see some tubes with a plastic t-piece like in the pic below. Disconnect as shown and use a small bolt to plug up the hose, use a bolt that is a little bit thicker than the inside diameter of the hose for a good seal. You can zip tie the hose so the bolt stays in there if you wish.
Benny.
post-1744-0-32786100-1348958812_thumb.jp
Disconnected it and got a guy from work to do a few drive by's for me. tough sound!... I reckon an aftermarket exhaust would sound better though. This will certainly do for now.
