  • Carnage on the Garage Floor
  • Member For: 15y 1m 25d
^^^ Sorry to hear mate. I guess the lesson here is get one shop to do the lot. Build the engine & fit then it's all on them. Hope somebody takes some responsibility otherwise the labour costs are gunna hurt. All the best with it :)
  • Like 2
  • Member For: 14y 11m 10d
Sorry to hear mate that's no good... Can u clarify wat u mean by to much clearance as I have had my engine rebuilt with spool rods and cp pistons and am now a little worried my engine has been running all good for 3000kms or so.
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 1m 5d
Tisk tisk to the engine builder
Measure 3times minimum then again "most" off the shelf items need finessing to be right, this is why blueprinting/balancing should be done correctly.
Some items like je pistons will have weights and code numbers attached to each slug so u can start to weigh up where your going to place them in order for balancing. I know spool rods are a cheap rod and weighing,measuring,after balancing is definately needed !!!
Bad luck mate I feel for ya
  • Member For: 13y 2m 22d
thanks mate and have spoken with the builder and said he has to pay for the engine refit this time as he had the chance to fix the problem first time and is not my fault this time round.
Ahh the highs and very lows of building a engine.
  • Member For: 17y 5m 18d
fark bad luck mate that really sux but rest assured if anyone can make your engine work its jon at plr. he built my rb26 and has sooooo much experience with basically every motor on the planet and has all the machinery under the sun. did anyone mention the head stud problems they suffer to him ? what were your rod bearing clearances ? 2 thou ?
I've been told by Lee that John from PLR said the rods had a side clearance of 30thou meaning the bearings are exposed by 30thou and not 10thou which is what the factory rods and atomic rods are. In older V8 engine this is ok as they run a thicker oil but because our engines run a super thin oil this much clearence is believed to be cause the oil to weep out and cause low oil pressure.
He said the bearing were spot on
Once he has the motor he is going to pressure test the cam bearing to see if there is a problem, then pressure test the rod clearances with the thin oil to find the leak. John understands that I wanted the car before Xmas and will try his hardest next week to fix it but probably won't have enough time
ah ok, side clearance ....... hope im wrong but that cant be fixed spool need to give u new rods. if that's the problem I mean. sorry if I missed but what head studs ? k got it its arp lol
Edited by mic
