  • Member For: 13y 2m 16d
  On 14/01/2013 at 10:34 AM, J@SNOT said:
Sounds like somethings up with the pump/gears/ set up install ....... Or uve got a blockage ina oil gallery/'s
Only thing I can think of the builder said he had to do some milling to get the atomic street girdle to fit. I was pretty sure you only had to mod the race plate. Does anyone know if the girdle sits very close to the oil pickup ?
The other thing that keeps popping up when talking between the builder and the dyno shop is the fact that the rods have 30thou of side clearence. The standard rods have 10thou
I'm just got no idea and its driving me bonkers
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 29d
Urr that's weird
Spool rods are balanced already, did the builder balance and blueprint the assembly ? that's the only reason I can think why the extra clearance is there
If the supplyed parts are true and correct then its in the builders hands
Not passing any blame across but a builder will weigh and measure even new supplied parts so he knows that hardwear is fine to begin with
  On 14/01/2013 at 10:59 AM, J@SNOT said:
Urr that's weirdSpool rods are balanced already, did the builder balance and blueprint the assembly ? that's the only reason I can think why the extra clearance is thereIf the supplyed parts are true and correct then its in the builders handsNot passing any blame across but a builder will weigh and measure even new supplied parts so he knows that hardwear is fine to begin with
Yeah he did balance the bottom end.
Well dude it looks like it needs to be pulled down and start with a good wash clean and re measure/assemble
Somethings going to rear its ugly head
  • Member For: 13y 11m 4d
I thought spool rods are made that way to try and keep the engine quieter and I think ull find even atomic rods are similarly offset... Cld be wrong though... Hope u get to the bottom of it either way...
Sent from my HTC Velocity 4G using Tapatalk 2
So got a question for everyone. Does anyone know if the factory VCT cam gears are meant to bleed oil ? Th exhaust one is leaking more than the intake one. I asked brad from atomic and he's pretty sure that they aren't meant to.
  • 4 weeks later...
  • Member For: 14y 6m 25d
Did some calcs on the flow figures posted.
average from .200 valve lift to .500 valve lift intake before mods 223.49 cfm
average from .200 valve lift to .500 valve lift intake after mods 229.83 cfm
average improvement total 6.34 cfm intake.
average from .200 valve lift to .500 valve lift exhaust before mods 162.26 cfm
average from .200 valve lift to .500 valve lift exhaust after mods 171.25 cfm
average improvement total 8.99 cfm exhaust.
  On 12/02/2013 at 1:22 PM, nitro xr6 turbo said:
any updates on the build?
Well got a call on Monday from the builder and he said he change the VCT gears and re pressurised the system and the gears did not leak as much as the original set, so fingers crossed that was the problem. The builder also said that because the gears aren't able to be checked normally that he is not going to pay for the 2 times the motor came out.
Wait and see that this was the problem.
