  • Member For: 19y 9m 14d
  On 15/04/2017 at 1:16 PM, arronm said:
466 on E85. No problem.  You guys are quick to underestimate the stock turbo.
Alghough I been checking out the GTW3884.  And the borgwarner 9180.
All confused which way to go for both cars.
Expand
Your tuner won't recommend either of those. He's a 6466 man. Just use a 6466 and be done with it.
  • Dropping a turd
  • Member For: 17y 5m 26d
True.  But if I go 9180 I can sort it through nizpro.  It's my cash so my choice.
  • Puff
  • Member For: 10y 2m 24d
The t3 bw is on par power wise with the bolt in gen2 gtx and the garrett is a grand cheaper just for the turbo, not taking into account fitting the dump for the bw.
If you're moving to a t4 flange (which you should be) then there are better options for the money in my opinion.
Yeah it's your money but make sure you don't spend lots of money for a small upgrade. It'd suck to be disappointed with just an extra 50 to 100 rwkw from a stock turbo.
Meh just my 2c anyway.
  • Puff
I know. I was making a comparison.
T4 bw might be your cup of tea. I'd choose a gtx42 myself just for cost efficiency.
  • Member For: 18y 30d
Gen 2 GTX will flow 600kw with the right supporting mods. Obviously paper ratings are always different from rear world, but it is a rated 900hp turbo
Much like the 6466, it will do it also but what is the life span haha
Edited by turboknapp
  • RNS10S
  • Member For: 18y 8m 6d
  On 16/04/2017 at 1:01 PM, arronm said:
Gen 2 gtx won't make enough power.  We are going over 600 rwkw .
Expand
So 466 is no problem with a 61mm turbo but can't make 600 with a 67mm????
I'm now confused....
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 22d
Don't ever try and understand Arron's thought process especially when the "Nizpro" % factor comes into things
#THEUNICORN
#NO250FORME
  • Like 5
