  • Member For: 14y 6m 9d
Had a good look at mine today and its not flanged after the diff but yours looks like it is Fletty? I think I'm just cut and weld if I have to flange both pipes.
After a lot of looking around while I was at supercheap getting oil I had a look at their exhaust tips and got a 2.75inch inlet with twin 3inch outlets (just gonna cut the inlet to 3inch) for $50 in stainless. Only problem is its got rolled tips so gonna weld everything up and put it all together and if its really that bad with rolled tips I'll cut them off and no harm done
  • Member For: 13y 2m 2d
Yea, I had the flange put in so I can still put the stock exhaust back on. Alternatively, cut it at the same point and weld straight 3" on.
Senna, I have thought about that, but im really happy with my ride height at the moment and cutting them down will lower it more? I have SSSL in the back and SSL in the front..
  • Forged Member
  • Member For: 18y 2m 21d
No, it shouldn't lower it more, just allow more travel and comfort
Did this yesterday guys. Looks almost identical the pictures Fletty put up but with polished stainless and twin 3" tips (ended up getting rolled tips real cheap and they sound good so not changing).
All up cost $80 for parts and I helped my old man weld it all up. Results are amazing! My dad has header back quad exhaust on his GT and this sounds very similar on idle then gets a little louder through the revs and backs of when cruising.
I'll try get a video but sound quality is pretty sh*t on iphones
  • Bronze Donating Members
  • Member For: 13y 9m 1d
  On 11/09/2012 at 12:22 PM, ScatterBrain said:
Here this is mine with the rear muffler removed.
That sounds crazy! How is it day to day? What cat back do you have?
Probably not the best pic but this is how it was all tacked in place. All that changed after this was being properly welded up. Unfortunately its not as easy as a job as you would think because the exhaust pipe going into the rear muffler isn't aligned with the tip so we had to cut a slight angle on each end of the straight pipe to make it all fit! Other than that I think it was about 2 hours work but a hoist was definitely needed.
post-42825-0-73656000-1348026019_thumb.j
  • 1 month later...
  • Member For: 17y 7m 27d
Loving the idea of pissing the rear muffler off, would put an end to thumping I get from the fat ford one banging on the car.
Is a tune required after doing this mod and the mod of removing the resistor ring?
