Bellato Donating Members 2,713 Member For: 14y 8m 11d Posted 10/09/12 11:34 PM Share Posted 10/09/12 11:34 PM Hey guys thought about doing the centre muffler but looked into what some of done and plus I wanna change the tip so rear muffler looked like a good option.Was thinking about cutting off the rear muffler, welding in a piece of 3inch stainless and putting twin 3inch tips on the end. Has anyone done this? What other options are there for the rear muffler?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/81864-rear-muffler-removal-for-straight-pipe/ Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 13y 1m 9d Gender: Male Location: Wollongong Posted 10/09/12 11:38 PM Share Posted 10/09/12 11:38 PM Where do you live? Take my section for a spin in your car. I got a bolt in and out twin 2.5 section, 260. 3 inch tips Link to comment https://www.fordxr6turbo.com/forum/topic/81864-rear-muffler-removal-for-straight-pipe/#findComment-1292949 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 11m 10d Gender: Not Telling Posted 10/09/12 11:52 PM Share Posted 10/09/12 11:52 PM Unlike centre muffler removal, deleting rear muffler will give better gas flow, therefore a slight increase in performance. Also it doesn't sound like a tractor. For best results use full 2.5 inch flange bolt up replacement. Also if doing yourself make sure you can get the car up high enough, as it is a bugger to get exhaust over the diff cradle. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/81864-rear-muffler-removal-for-straight-pipe/#findComment-1292956 Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 14y 2m 5d Gender: Male Location: Victoria Posted 11/09/12 12:04 AM Share Posted 11/09/12 12:04 AM Yeah it's a PITA without a hoist. Link to comment https://www.fordxr6turbo.com/forum/topic/81864-rear-muffler-removal-for-straight-pipe/#findComment-1292959 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 11d Posted 11/09/12 12:51 AM Author Share Posted 11/09/12 12:51 AM Where do you live? Take my section for a spin in your car. I got a bolt in and out twin 2.5 section, 260. 3 inch tipsGriffith NSW.Yea I wanted to make a proper section with flanges etc so I can swap it over later but for all the money and work to go over the diff could get a catback lol. I don't have a hoist but I can use a forklift if need be lol. From having a look cause I'm going to cut the muffler off straight after the diff I should be able to take it off a lot easier than normal, putting it on will be sh*t Link to comment https://www.fordxr6turbo.com/forum/topic/81864-rear-muffler-removal-for-straight-pipe/#findComment-1292988 Share on other sites More sharing options...
fletty Member 191 Member For: 13y 4m 5d Gender: Male Posted 11/09/12 01:20 AM Share Posted 11/09/12 01:20 AM This might help Bellato, I have also put a flange on my standard rear box so I can revert back at anytime.Flange is just at the point where the factory piping starts to go straight, this way it will be very simple to hang and centreVeiw from the back, completely straight if you cut and weld the flange right, im looking at putting a collector in now so it will be flange, 100mm straight 3" into split collector, then twin 3" all the way out with staggered tips, will look alot more neater as the single 3" does look a little small on some angles.Sorry for the poor quality pics, but you get the idea.. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81864-rear-muffler-removal-for-straight-pipe/#findComment-1293001 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 11d Posted 11/09/12 01:54 AM Author Share Posted 11/09/12 01:54 AM Sweet, that's pretty much what I want to do but with twin tips. Did you do this yourself or get a shop to do it? The bloke I went too basically didn't want to flange it cause it was too much work for him! and then quoted $250-$300 (with a $120 tip) and all he had to do was cut then weld.On a side note what are peoples views on these. Finding it impossible to get a straight cut twin 3" tip for under like $120 (which is way too much for what it is) and I don't want rolled tips from all the bad reviews. So got these 2 options at the moment. If anyone has a pic of the dump style tips would be much appreciated, thinking I'm leaning that way.http://www.ebay.com.au/itm/261087169267?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1589wt_1165Don't really like the angle in on this and because its cheap I'd say it might be the same as rolled tips and muffle a bithttp://www.ebay.com.au/itm/261095887394?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1672wt_1165And this one is what I like but trying to find something cheaperhttp://www.ebay.com.au/itm/170789518338?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_675wt_1165 Link to comment https://www.fordxr6turbo.com/forum/topic/81864-rear-muffler-removal-for-straight-pipe/#findComment-1293021 Share on other sites More sharing options...
fletty Member 191 Member For: 13y 4m 5d Gender: Male Posted 11/09/12 02:05 AM Share Posted 11/09/12 02:05 AM An exhaust shop did mine, only because I wanted to make sure I could put the standard rear box back on and it would sit perfectly. I will be doing the collector and twin 3" myself.Something just like this so I can utilise the existing flange and hanger etc 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81864-rear-muffler-removal-for-straight-pipe/#findComment-1293025 Share on other sites More sharing options...
chrisg6et Donating Members 12 Member For: 12y 10m 12d Posted 11/09/12 05:35 AM Share Posted 11/09/12 05:35 AM I like the Twin idea mateGot the muffler cut off on my G6et and kept stock tip cost me $60 at an exhaust shopGives it a nice note and insnt too loud and when fully on it and it back fires and sounds like a gunshot :-) Link to comment https://www.fordxr6turbo.com/forum/topic/81864-rear-muffler-removal-for-straight-pipe/#findComment-1293152 Share on other sites More sharing options...
lrmcdowell Donating Members 730 Member For: 13y 10m 5d Gender: Male Location: Randwick, sydney Posted 11/09/12 07:40 AM Share Posted 11/09/12 07:40 AM I have the centre muffler removed...it would sound sh*t with the rear removed as well wouldnt it? Link to comment https://www.fordxr6turbo.com/forum/topic/81864-rear-muffler-removal-for-straight-pipe/#findComment-1293203 Share on other sites More sharing options...
