  • Member For: 16y 1m 6d
Just had a rod let go and now have 3 inspection holes in the block and sump. Im wishing to buy a non turbo ba motor and ONLY use the block and crank and fit a spool kit to the motor. My question is are they they same spec?
  • Forged Member
  • Member For: 18y 3m 9d
Yep, crank and block is the same. You'll either need to use a turbo sump or drill and tap an N/A for the turbo return line.
I don't think you have to worry about the water lines though...someone might be able to correct me
