Oil Leakage From Turbo
dazzalenko
  • Bronze Donating Members
  • Member For: 13y 5m 26d
Really need more info but the most common leak is from the front timing cover, oil can drip off either the power steering pump bracket or will drip straight off the bottom of the sump. Have had front cover leaks run backwards along the head gasket and leak down the back of the engine dripping off rear of sump also
