fgxr6tsa Member 15 Member For: 13y 3m 22d Gender: Male Location: Adelaide Posted 04/09/12 06:57 AM Share Posted 04/09/12 06:57 AM Hi,Can anyone tell me where this is located and how difficult it is to replace, is it in the boot or under car? Link to comment Share on other sites More sharing options...
fgxr6tsa Member 15 Member For: 13y 3m 22d Gender: Male Location: Adelaide Posted 04/09/12 07:14 AM Author Share Posted 04/09/12 07:14 AM Should also read fg Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 8m 4d Gender: Male Posted 04/09/12 08:48 AM Share Posted 04/09/12 08:48 AM The fuel sender is inside the fuel tank, if its a sedan remove the back seat and the black cover on passenger side, undo the fuel lines and electrical connector. Spin the lock ring off and remove the fuel pump module, you will then need to reach inside the tank towards the rear of the car and youl feel the sender, slide it up and pull it out. If is a ute fuel tank needs to come out. Link to comment Share on other sites More sharing options...
fgxr6tsa Member 15 Member For: 13y 3m 22d Gender: Male Location: Adelaide Posted 04/09/12 12:08 PM Author Share Posted 04/09/12 12:08 PM Cheers for that Link to comment Share on other sites More sharing options...
fgxr6tsa Member 15 Member For: 13y 3m 22d Gender: Male Location: Adelaide Posted 08/09/12 02:35 AM Author Share Posted 08/09/12 02:35 AM Have the back seat off, have removed black cover and undone electrical connector, how do the fuel lines come off and with the oring is it just a matter of hitting it in anti clockwise direction Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 8m 4d Gender: Male Posted 08/09/12 07:12 AM Share Posted 08/09/12 07:12 AM Use a small screwdriver to pry the clips out on the inside of the connector, and yes the lockring spins anti clockwise Link to comment Share on other sites More sharing options...
