  • Forged Member
  • Member For: 18y 3m 2d
  On 10/09/2012 at 12:56 AM, tab said:
Bonnet hot?
Always found it the easiest panel, but only ever done it at home where the only driving is putting it back in the garage.
Yeah, I did think that (made that mistake a couple of years ago) but I parked it at 9:30am, washed it, masked it up then clay barred it. I think it was around 11:30 or 12 before I started with any product on the bonnet. Didn't feel hot at all....
Guest XR09
  • Guests
The bonnet, roof and boot all cop the most sun. The paint will be drier on those panels. The bonnet more so, as it has to cope with engine heat from below as well. So it gets a head start every time in the heat up stakes.
If you look at the paint under a microscope it isn't flat. It needs fillers to protect it and stop the oils leaching...paint fade.
The drier it gets the more it opens up.
Hard as it sound you need to smooth off the paint. You can get a decent orbital and waste a pad and a lot of compound. Or one sheet of 3M1800...up to you.
People go off about using paper on a car...but they do use it...a lot. For that reason. It's not hard and probably better than a buff and a hard pad with compound. And you would more than likely hit it with a hard pad to smooth it out.
But if you do use paper you will need to make it shine again with a buff
  • Forged Member
Ah, yeah I think I might have to give it a wet sand....I'll probably cry while I'm at it though...lol
  • Sucker
  • Moderating Team
  • Member For: 21y 14d
Just make sure it's ultra-clean first otherwise you'll get embedded dirt scratching the sh*t out of it. I.e. use a scourer or steel wool and morning fresh. :nod:
  • FREAKY
  • Member For: 15y 4m 14d
go easy on the wet sanding (shouldnt be needed)
revise your cutting compound materials pat
ford are not famous for their generous clear coats!!!!!!!
  • Member For: 21y 8m 5d
For clay barring I have found that the 3M Blue coloured clay bar has been the best for my f6x to remove Tar and anything else. I was previously using the meguires but it is really only suited for someone with a car that is kept in excellent condition like most of you fellas as the 3M is a little more harsh. Also I did use the Turtle brand of liquid clay sample that I had from ages ago and used it with the meguires and 3M bar with good success.
I swear though that ford made the territory shape to collect all excess road tar off of our main roads as my car is just fcking ridiculous everytime I go out in it! I want to know how the fck tar manages to get on the rear spoiler lip of my car when it is 6ft off the ground and know where near the wheels!
