Falky100 Donating Members 305 Member For: 13y 5m 5d Gender: Male Posted 04/09/12 02:14 PM Share Posted 04/09/12 02:14 PM Hop in your car put the accelerator flat to the floor and then wind the car over for 10 seconds (The car shoudnt start) as far as I know, it resets the throttle position sensor or something... Worth a try though. Link to comment https://www.fordxr6turbo.com/forum/topic/81743-intermittant-power-loss-in-throttle/page/2/#findComment-1289846 Share on other sites More sharing options...
jayyraad Member 19 Member For: 12y 7m 14d Posted 05/09/12 03:18 AM Author Share Posted 05/09/12 03:18 AM Recieved the pdf file! Cheers!Gonna try test it out this weekend .. (hopefully)Only thing is the ETC light dosnt flash as far as iv seen whilst driving it. And yes. Iv tried resetting the TPS with the cranking at full throttle. ill plug a scanner back in.. Got a couple scanners here. So ill plug it back in again and see what comes up. Iv spoken to a friend who used to work at ford and I explained the problem. And he said everything that metalphreak has said in regards to the TPS. & PPSThe one thing he did add is the turbo actuator.And said its possible that the actuator is sticking and not opening. The computer recognizes this and cuts the throttle to prevent overboost (which is one of the codes that occurs after this fault) .. As I havnt seen any throttle codes come up yet. Does this make any sense? And is it possible this could be the case? Link to comment https://www.fordxr6turbo.com/forum/topic/81743-intermittant-power-loss-in-throttle/page/2/#findComment-1290043 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 8m 19d Gender: Male Posted 05/09/12 08:11 AM Share Posted 05/09/12 08:11 AM Could be stuffed actuator, a tps/throttle body/ app will always set a code.... Link to comment https://www.fordxr6turbo.com/forum/topic/81743-intermittant-power-loss-in-throttle/page/2/#findComment-1290242 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 4m 25d Gender: Male Location: SE Melbourne Posted 08/09/12 01:08 AM Share Posted 08/09/12 01:08 AM (edited) hey bionic, so I had a better look in the day time and the loud ticking noise is coming from the boost solenoid (I think).Anyway, I logged the wastegate, are you able to log yours to see if the graph looks the same?The graph is simply showing WOT for about 10 secondsedit: just remembered you may be running an external gate. damn Edited 08/09/12 01:10 AM by Paulie2256 Link to comment https://www.fordxr6turbo.com/forum/topic/81743-intermittant-power-loss-in-throttle/page/2/#findComment-1291748 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 8m 19d Gender: Male Posted 08/09/12 07:14 AM Share Posted 08/09/12 07:14 AM Yeh im running external gate and eboost sorry bud Link to comment https://www.fordxr6turbo.com/forum/topic/81743-intermittant-power-loss-in-throttle/page/2/#findComment-1291868 Share on other sites More sharing options...
jayyraad Member 19 Member For: 12y 7m 14d Posted 18/09/12 10:20 AM Author Share Posted 18/09/12 10:20 AM So... After the weekend just passed iv come to the conclusion of my wastegate is rooted. Because it was opening up Sometimes the ECU would cut the throttle back to prevent overboosting and my motor going kabooom! Reasons iv decided is the car did not log any throttle codes which as said previously wud always log a code and only a "wastegate not open under pressure" code was always logged. And now. My actuator no longer opens. And havnt had any throttle loss. So.. Looks like its gonna be an expencive one. Bigger and better acutator, port and flapper mod to turbo. X3 flash and a tune.... Tops. Haha! Cheers for all the help everyone! and I hope this thread helps others too! Link to comment https://www.fordxr6turbo.com/forum/topic/81743-intermittant-power-loss-in-throttle/page/2/#findComment-1296787 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 11m 21d Gender: Male Location: Victoria Posted 18/09/12 10:26 AM Share Posted 18/09/12 10:26 AM Reving it in neutral won't show you anything relating to boost.It does sound like a stuffed cat to me.I fixed a mates car once that would not rev passed 3000rpm. It was like it had a limiter. Turned out the cat internals had broken away and turned sideways on the housing practically blocking the exhaust. Link to comment https://www.fordxr6turbo.com/forum/topic/81743-intermittant-power-loss-in-throttle/page/2/#findComment-1296792 Share on other sites More sharing options...
jayyraad Member 19 Member For: 12y 7m 14d Posted 18/09/12 10:32 AM Author Share Posted 18/09/12 10:32 AM It would always rev out in neutral or under load .. Jus the throttle wouldnt br anywhere near as responsive.. But as I said plugged scanner in several times. Not one throttle code only actuator code. Link to comment https://www.fordxr6turbo.com/forum/topic/81743-intermittant-power-loss-in-throttle/page/2/#findComment-1296795 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 8d Gender: Male Location: OZ Posted 18/09/12 12:14 PM Share Posted 18/09/12 12:14 PM (edited) On 08/09/2012 at 1:08 AM, Paulie2256 said: hey bionic, so I had a better look in the day time and the loud ticking noise is coming from the boost solenoid (I think).Anyway, I logged the wastegate, are you able to log yours to see if the graph looks the same?The graph is simply showing WOT for about 10 secondsedit: just remembered you may be running an external gate. damnSolenoid ticking.......simple fix Edited 18/09/12 12:15 PM by IH8TOADS Link to comment https://www.fordxr6turbo.com/forum/topic/81743-intermittant-power-loss-in-throttle/page/2/#findComment-1296848 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 11m 21d Gender: Male Location: Victoria Posted 18/09/12 12:23 PM Share Posted 18/09/12 12:23 PM That's like an Edit V1 issue. Didn't think that would pop up these days. Link to comment https://www.fordxr6turbo.com/forum/topic/81743-intermittant-power-loss-in-throttle/page/2/#findComment-1296850 Share on other sites More sharing options...
