Trent0 The Toxic Rocket Donating Members 574 Member For: 15y 2m Gender: Male Location: Brisbane Posted 02/03/16 08:49 AM Author Share Posted 02/03/16 08:49 AM thanks for the heads up! How can I go about shielding the bay & bonnet from the exhaust housing temp? Link to comment https://www.fordxr6turbo.com/forum/topic/81728-5rwkw-na-turbo-conversion/page/27/#findComment-1581255 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 8m 25d Posted 02/03/16 09:06 AM Share Posted 02/03/16 09:06 AM Buy a stainless steel pot from woollies and cut it up and put it over the rear housing. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81728-5rwkw-na-turbo-conversion/page/27/#findComment-1581257 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m Gender: Male Location: Probably above atmospheric pressure Posted 02/03/16 12:22 PM Share Posted 02/03/16 12:22 PM Remove bonnet, that fixes everything! Link to comment https://www.fordxr6turbo.com/forum/topic/81728-5rwkw-na-turbo-conversion/page/27/#findComment-1581276 Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 15y 2m Gender: Male Location: Brisbane Posted 04/05/16 12:01 AM Author Share Posted 04/05/16 12:01 AM I used to have one of those "drift" vented bonnets, should have kept it I pulled out the gearbox yesterday to add a spacer behind the csc as the crush was out and getting into gears (especially reverse which was near on impossible) was getting difficult. I highly recommend using a skateboard to aid in the process, 2 Link to comment https://www.fordxr6turbo.com/forum/topic/81728-5rwkw-na-turbo-conversion/page/27/#findComment-1588690 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,569 Member For: 17y 2m 14d Gender: Male Location: Melbourne Posted 04/05/16 12:05 AM Share Posted 04/05/16 12:05 AM Hahaha, I do approve of the idea of using a rolling device to move the gearbox All back together now with the better crush depth? Link to comment https://www.fordxr6turbo.com/forum/topic/81728-5rwkw-na-turbo-conversion/page/27/#findComment-1588692 Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 15y 2m Gender: Male Location: Brisbane Posted 04/05/16 05:16 AM Author Share Posted 04/05/16 05:16 AM Back together now, just bleeding clutch. I really want to piss that hard line off and run braided hose from the res to the pedal and pedal to the slave, has anyone done it before? The spacer the old man made last night, 2mm sheet aluminium. 112mm diameter with a 38mm inside cut out to fit shaft and clear the chamfer. Link to comment https://www.fordxr6turbo.com/forum/topic/81728-5rwkw-na-turbo-conversion/page/27/#findComment-1588750 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,569 Member For: 17y 2m 14d Gender: Male Location: Melbourne Posted 04/05/16 05:20 AM Share Posted 04/05/16 05:20 AM The hard line you can just buy a replacement from Mal Wood... I don't know the specs enough to know if you could knock one up at your local enzed/pirtek/etc. let us know how the gear selection goes. mounted that plate under the CSC? slick bit of kit, definitely Link to comment https://www.fordxr6turbo.com/forum/topic/81728-5rwkw-na-turbo-conversion/page/27/#findComment-1588753 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 1d Gender: Male Location: Perth Posted 04/05/16 05:29 AM Share Posted 04/05/16 05:29 AM Mal's replacement still use the short plastic line from the MC to the Dash 4 adaptor. once of these each "should" work http://www.ebay.com/itm/TREMEC-T56-TR6060-HYDRAULIC-CLUTCH-LINE-FITTING-AN-4-LINE-6-SPEED-SWAP-/111147459015?hash=item19e0e7a1c7:g:PhgAAOSwFGNWSow3&vxp=mtr Link to comment https://www.fordxr6turbo.com/forum/topic/81728-5rwkw-na-turbo-conversion/page/27/#findComment-1588756 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 8m 25d Posted 04/05/16 01:54 PM Share Posted 04/05/16 01:54 PM sh*t that little thing is expensive. I just took the standard end out of the plastic line cut the barb off and welded a 1/4 olive clamp fitting (dunno what you call it really it's just a stainless line end.) then used another one to screw into the slave, slave should have 1/8npt thread. Found a flexible hydraulic line at work with 1/4 barb type ends that I could put straight into the olive fitting. Total cost of $0. Making custom components FTW. Here is a pick of my setup if you zoom in you will see the fitting that I tig welded together. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81728-5rwkw-na-turbo-conversion/page/27/#findComment-1588890 Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 15y 2m Gender: Male Location: Brisbane Posted 05/05/16 11:18 AM Author Share Posted 05/05/16 11:18 AM I will be looking into that, looks awesome mate! So thinking the 2mm spacer wasn't enough. I can engage reverse better, but once in gear, clutch completely in, the car still creeps backwards. Throw another 2mm spacer in it? Link to comment https://www.fordxr6turbo.com/forum/topic/81728-5rwkw-na-turbo-conversion/page/27/#findComment-1589000 Share on other sites More sharing options...
