  • The Toxic Rocket
  • Member For: 15y 1m 29d
After reading about a few guys on here modifying their gear sticks for a more direct feel, I decided to give it a go as well. 11/10 recommend. A bit noisier but the feel and throw is incredible. The old man made the fittings up for me.
It was also about time to replace the centre bearing as it was pretty well buggered and causing a vibration through the drive line.
[URL=https://imageshack.com/I/hlgjHjcvj][IMG]http://imagizer.imageshack.us/v2/1280x1024q90/633/gjHjcv.jpg[/IMG][/URL]
[URL=https://imageshack.com/I/pcN9ZN8Fj][IMG]http://imagizer.imageshack.us/v2/1280x1024q90/912/N9ZN8F.jpg[/IMG][/URL]
[URL=https://imageshack.com/I/hlL9qHyNj][IMG]http://imagizer.imageshack.us/v2/1280x1024q90/633/L9qHyN.jpg[/IMG][/URL]
[URL=https://imageshack.com/I/p51Z22Huj][IMG]http://imagizer.imageshack.us/v2/1280x1024q90/905/1Z22Hu.jpg[/IMG][/URL]
Edited by Trent0
  • Member For: 17y 6m 29d
Well this was a bit awkward to do.  "Insert other media" in bottom left, then after it appears I had to click back in and press enter to go to a new line before doing it again.  I wish the IMG code shortcut still worked...maybe there's a new one.
Seems it's been changed somehow... see if I can figure this out
wait I think it's normal HTML  with the less than/greater than symbols around img src= etc
wait no just paste the direct link and it just makes it into the image after a second... I think.
Edited by -Stever-
  • The Toxic Rocket
thanks steve! I tried changing the links a few times with the edit function but the page kept timing out :/
  • 5 weeks later...
  • The Toxic Rocket
Over the last few weeks I've finally gotten around to getting everything I needed to swap covers to the fg style. Really happy with it :) It looks a lot more refined.
Don't mind the bolts on top, fyi, bseries coil cover bolts don't fit
  • The Toxic Rocket
I had a bit of a spirited drive up Mt Glorious the other day, upon reaching the top I pop the bonnet and idle the car for a few minutes to let it cool down. This is what I saw.
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 23d
Precision highly do not recommend using turbo beanies!!!
  • The Toxic Rocket
Someone should tell Golbeys Parts as it came with it LOL. Also is falling a part.
can you elaborate more Jetus?
For 1 the use of a turbo beanie voids warranty with precision
for 2 the reason stems from what you're seeing and further complicates things regarding blocking the oil gallery with baked oil residue
  • Like 2
