  • Member For: 18y 10m 16d
Which injector and duty cycle is being used with it?
any combination you like, I just want to know about fuel pump flow
  • You've changed man....
  • Member For: 14y 3m 16d
I want to know what micks up to
  • Tampon inserted, Auto Acquired, next purchase a new handbag
  • Member For: 17y 23d
Making ultimate super soaker out of left over parts?
  • Like 2
  • Member For: 21y 8m 6d
I'm going to make an assumption and say it's the same pump used in the GT. From what I'm lead to believe they flow between 330-350LPH at a base fuel pressure of 50psi. In a GT they are good for up to approx 430rwkw.
Regards,
Benny.
Regards,
Benny.
Ok so after reading Mick's other post it seems not. Like he said "never assume".
Benny.
  • Member For: 17y 8m 8d
I have seen 350rwk with nizpro injectors on standard fuel pump of an xr6t on e85 and 310ish on 98. that's with turbo maxed out
