Fg 1000Hp Twin Pump Intank Module
  • Member For: 19y 4m 3d
So the Walbro 460 kit wont surge? Is it easy enough to install yourself? Id assume you'd need a retune? What power is it limited at on 98 and e85 with Dekka 60's?
Correct no surge.
No re-tuning needed if you vehicle tune is currantly running standard / corerect fuel pressures for you car.
Our Walbro 460 fuel module can support approx 450 fwkw on 98 or 95 octane.
Your dekka 60s will support this power at approx 95% duty cycle @ 11.8 :1 fuel ratio.
Our Streetfighter 1000HP Intank module can support standard power and up to 850fwkw , however you would need our KPM2000cc Injectors.
  • 2 months later...
KPM are overwhelmed by the feedback we have recieved from our BF MK2 / FG Sedan Streetfighter 1000hp Fuel system. With easy fit, no noises or smells and completely legal our customers are now appreciating the advantages and safety this engineered fuel system has over external surge tank set ups.
We have now finalised the Streetfighter 1000hP Module design for the BF MK2/FG Ute range and are set up for production.
As this fuel system is of high quality materials and manufacture is extremely expensive we are after expression of interest so we can have an idea of manufacture numbers for our first production run.
Streetfighter1000HpTwinIntankPumpModulev
Edited by KPM Motorsport
The pics look like the stock OEM reg to me. These must be hi-flowed to return more fuel yeah?
Correct.
We purchase new Bosch part # regulators and precision high flow and bench test them to perfectly suit the Ford fuel systems.
The Bosch Motorsport equivalant is over $700.
  • 3 weeks later...
How much is the FPR by itself ?
The split up pricing of the package is
High flow Bosch Fuel pressure reulator $195
Plug and Play wiring kit $105
Streetfighter 1000hp Anti-Surge module $1390
You mentioned ratter will be recieving one for testing, has this happened yet?
I have contacted Ratter on several occasions to organise a time when he is able to test.
I am leaving up to him fit in his schedule when he is best able to.
