  • Member For: 22y 30d
first thing take the rocker cover and have a look. Check all lobes of the cam and rollers on the rocker arm. Check all springs and retainers for proper fitting. You can check clearances for hydraulic lifters. There is a correct proceedure . You can also check valve stem heights with rocker gear off. check VCT. Look for any unusual marks. You can even clean lifters by taking them apart.
If you cant find anything then just replace all lifters and see how you go.
  • New Member
  • Member For: 12y 9m 10d
Make sure you are using the correct viscosity oil. Used to get loud lifter noise in my AU when using thicker oil, went thinner and after a week the lifter noises dissappeared.
Worth a shot before changing all your lifters.
