bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 8m 11d Gender: Male Posted 11/09/12 09:49 AM Share Posted 11/09/12 09:49 AM As I said in the other post, iv had a pcm cause this issue, if I were you I would disconnect the purge solenoid line at the manifold and block the manifold side, fill the car and see if it still happens. The purge solenoid is located near the passenger strut tower close to the firewall, its feed line runs next to the main fuel lines, its a little black box with lines either end and a two pin electrical connector. The one I had also had no fault codes and in the end we bench tested it and confirmed the pcm was holding the purge solenoid open at all times which, when filling up, will fill the manifold with vapour and cause start/stall rough running on initial startup after a fill but be fine evey other time. This is my experience hope it helps. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m Gender: Male Location: SW Sydney Posted 11/09/12 09:51 AM Share Posted 11/09/12 09:51 AM Threads merged, no need to discuss it across two separate threads Link to comment Share on other sites More sharing options...
was270 Member 26 Member For: 12y 7m 10d Gender: Male Location: Belconnen ACT Posted 11/09/12 09:57 AM Author Share Posted 11/09/12 09:57 AM Thanks bionic. Ill give it a go on the weekend. It didnt happen when I filled up this morning but it did overflow even after cutting out on the first click of the bowser. Homuch is a replacement PCM likely to cost me?? Is there no way of rectifying whislt getting a tune?? Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 8m 11d Gender: Male Posted 11/09/12 09:59 AM Share Posted 11/09/12 09:59 AM As it was not a software issue id say it was internal fault so new pcm was required, changing tune parameters probably wont do anything... But I would confirm the fault first before going any further Link to comment Share on other sites More sharing options...
was270 Member 26 Member For: 12y 7m 10d Gender: Male Location: Belconnen ACT Posted 14/09/12 07:48 AM Author Share Posted 14/09/12 07:48 AM Thanks for the info. I'm going to book it in with Spiro at Autotech to take a closer look Link to comment Share on other sites More sharing options...
was270 Member 26 Member For: 12y 7m 10d Gender: Male Location: Belconnen ACT Posted 10/08/13 10:24 PM Author Share Posted 10/08/13 10:24 PM All sorted, faulty purge solenoid and $100 to fix it at Peter Warren. Link to comment Share on other sites More sharing options...
stretch4660 Member 122 Member For: 12y 3m 15d Posted 13/08/13 07:39 AM Share Posted 13/08/13 07:39 AM Holy sh*t, my fg has a pretty similar problem I've been trying to chase down for a little while now, idles rough and stalls every now and again, and yeah normally after fueling, bowser at petrol station takes a million attempts to get filling the tank, I'll test the purge solarnoid tomorrow n see what the deal is, might just bite the bullet and replace it, $100 is nothin Link to comment Share on other sites More sharing options...
Jason87 Member 37 Member For: 12y 7m 12d Posted 17/03/15 04:21 AM Share Posted 17/03/15 04:21 AM Does anyone have an aftermarket brand or part number where I can get the solidnoid from genuine ford 1 is $295bux Link to comment Share on other sites More sharing options...
was270 Member 26 Member For: 12y 7m 10d Gender: Male Location: Belconnen ACT Posted 03/05/15 12:50 AM Author Share Posted 03/05/15 12:50 AM Repco will have a listing for it. I know someone else who has purchased one from there. Link to comment Share on other sites More sharing options...
