  • Bronze Donating Members
  • Member For: 13y 10m 9d
As I said in the other post, iv had a pcm cause this issue, if I were you I would disconnect the purge solenoid line at the manifold and block the manifold side, fill the car and see if it still happens. The purge solenoid is located near the passenger strut tower close to the firewall, its feed line runs next to the main fuel lines, its a little black box with lines either end and a two pin electrical connector. The one I had also had no fault codes and in the end we bench tested it and confirmed the pcm was holding the purge solenoid open at all times which, when filling up, will fill the manifold with vapour and cause start/stall rough running on initial startup after a fill but be fine evey other time. This is my experience hope it helps.
  • Forged Member
  • Member For: 18y 3m 29d
Threads merged, no need to discuss it across two separate threads :spoton:
  • Member For: 12y 9m 7d
Thanks bionic. Ill give it a go on the weekend. It didnt happen when I filled up this morning but it did overflow even after cutting out on the first click of the bowser. Homuch is a replacement PCM likely to cost me?? Is there no way of rectifying whislt getting a tune??
As it was not a software issue id say it was internal fault so new pcm was required, changing tune parameters probably wont do anything... But I would confirm the fault first before going any further
  • 10 months later...
  • Member For: 12y 5m 13d
Holy sh*t, my fg has a pretty similar problem I've been trying to chase down for a little while now, idles rough and stalls every now and again, and yeah normally after fueling, bowser at petrol station takes a million attempts to get filling the tank, I'll test the purge solarnoid tomorrow n see what the deal is, might just bite the bullet and replace it, $100 is nothin
  • 1 year later...
  • 1 month later...
