hsv0505 Member 8 Member For: 12y 8m 20d Posted 28/08/12 09:16 AM Share Posted 28/08/12 09:16 AM I'm going to look at a 05 BA mk2 manual with 130,000ks. What are some things I should look for such as tell tale signs of problems etc.Thanks guys Link to comment https://www.fordxr6turbo.com/forum/topic/81659-what-to-look-for-ba-mk-2-manual/ Share on other sites More sharing options...
bradles024 Donating Members 1,145 Member For: 15y 5m 26d Gender: Male Posted 28/08/12 09:20 AM Share Posted 28/08/12 09:20 AM Noisy turbo right after cars turned off Link to comment https://www.fordxr6turbo.com/forum/topic/81659-what-to-look-for-ba-mk-2-manual/#findComment-1286490 Share on other sites More sharing options...
hsv0505 Member 8 Member For: 12y 8m 20d Posted 28/08/12 09:27 AM Author Share Posted 28/08/12 09:27 AM On 28/08/2012 at 9:20 AM, bradles024 said: Noisy turbo right after cars turned offSo start it up then turn it off, check under the hood to see if the turbos noisy? To easy. Link to comment https://www.fordxr6turbo.com/forum/topic/81659-what-to-look-for-ba-mk-2-manual/#findComment-1286492 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 13d Gender: Male Posted 28/08/12 09:34 AM Share Posted 28/08/12 09:34 AM A little bit of bearing noise is normal actually... Much more noticable if it has a turbo side intake though... Just take it for a drive, load it up make sure it doesnt missfire or blow smoke etc, make sure its cold when you start it to run through full operating temps etc, check for noisey suspension and squeaks/rattles exhaust leaks etc, check icc operation, heater an a/c operation ( make sure centre vent temps are identical on full hot) Link to comment https://www.fordxr6turbo.com/forum/topic/81659-what-to-look-for-ba-mk-2-manual/#findComment-1286499 Share on other sites More sharing options...
4runner Donating Members 215 Member For: 20y 9m 19d Location: Sydney Posted 28/08/12 09:58 AM Share Posted 28/08/12 09:58 AM Standard clutch is not up to a modded engine. Mine was slipping in 4th, 5th and 6th with only 268 rwkw. Easily fixed with a Mal Wood Option 3.With over 100,00kms, the rear diff bushes if original are probably knackered. Don't let me put you off though, they are great cars. Good luck - there are plenty of bargains out there. Link to comment https://www.fordxr6turbo.com/forum/topic/81659-what-to-look-for-ba-mk-2-manual/#findComment-1286524 Share on other sites More sharing options...
IMLOCO Member 397 Member For: 13y 1m 25d Posted 28/08/12 10:02 AM Share Posted 28/08/12 10:02 AM A descent cooler set up goes along way in my opinion Link to comment https://www.fordxr6turbo.com/forum/topic/81659-what-to-look-for-ba-mk-2-manual/#findComment-1286526 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 19d Gender: Male Location: Sydney Posted 28/08/12 11:07 AM Share Posted 28/08/12 11:07 AM Dont 4get the simple stuff likepower windowselectric mirrorsrustroof carpetworn seatsdents n scratchswarped brakesselects gears easy thinking 2nd and 3rd mainlyoil leaks on diff, gearbox, motorrear diff bushya should be able to hear the turbo wind down for atleast 30-40seconds IMOtyre wearchips in paint on the front endgearstick slopall lights are workingoil level, coolant level, powersteering fluid level, clutch fluid level also see what condition its inwheel bearing noises when ya turn left or rightrattly suspensiondiff backlashengine noisesAir con actually does cool and does heatthermo fans arent kickin in like crazy when the car is doing sfaengine mountspanel alignmentJust to name a few... alot of these you will find and expet to see on a car but they do help ya cut the price down. Link to comment https://www.fordxr6turbo.com/forum/topic/81659-what-to-look-for-ba-mk-2-manual/#findComment-1286556 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 5m 3d Gender: Male Location: CQ Posted 28/08/12 11:31 AM Share Posted 28/08/12 11:31 AM Make sure it is actually an 05 mk 2 and make sure it has 6gears... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81659-what-to-look-for-ba-mk-2-manual/#findComment-1286565 Share on other sites More sharing options...
hsv0505 Member 8 Member For: 12y 8m 20d Posted 28/08/12 11:48 AM Author Share Posted 28/08/12 11:48 AM BTW, thanks heaps for this guys/. Another thing, it has 132,000 kms, leather and premium audio would I be pushing it to aim for $12,500? Link to comment https://www.fordxr6turbo.com/forum/topic/81659-what-to-look-for-ba-mk-2-manual/#findComment-1286575 Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 14y 15d Gender: Male Location: Victoria Posted 28/08/12 12:04 PM Share Posted 28/08/12 12:04 PM Are you looking to modify it much? Link to comment https://www.fordxr6turbo.com/forum/topic/81659-what-to-look-for-ba-mk-2-manual/#findComment-1286587 Share on other sites More sharing options...
