Camber & Toe Relationship Changes
tdt84
  • New Member
  • Member For: 13y 5m 26d
Hi guys!
Just fitted an adjustable camber kit to the front of my BA Turbo.
Have it set at max neg camber just to see how much I can get for track work then I'm gonna set it up for street duties as this is where it spends most of its time.
Took it for a quick spin last night and omg what a difference it has made, totally transformed the car! Feels so much more responsive and grippy at the front end and could not get it to push even going around a large roundabout that's off camber doing 60kph!! Before you could feel it roll on its outer edge of the tire and couldn't push much harder.
My question is, in these cars how does adjusting camber affect toe settings? I hope to have a little toe in when its set to about -1.5 camber but will increasing my neg camber dial in more toe in or toe out?
I'm thinking because the tie rod is at the rear of the wheel assembly it will cause it to toe out when neg camber increases...I'm hoping this is the case
Can anyone verify this?
  • Forged Member
  • Member For: 18y 13d
No, you will end up with more toe in as you add negative camber.
As the wheel (or hub) leans in from the top, the rack and tie rod end will force the back of the wheel out - this I turn gives you Toe IN
  • New Member
Ahh yeah makes sense...thanks!
You don't happen to know how much toe changes with one full turn of adjustment hey?
hoping once I get an alignment for street driving that I can just adjust it myself for the track then put it back where it was when I get home.
  • Forged Member
From memory 1 spline is around 1-1.5mm...could be less though.
Adjusting it at the track is fine, all providing your steering rack is centred and you run a string line to make sure that you get the adjustment correct
  • New Member
Not too far of a drive to the track so I'd probably spend the day before getting it setup right then adjust it again once I'm home.
Thanks for the help!
  • Member For: 16y 7m 26d
On the FG I change the camber to 3.5deg negative the night before a track day.
post-16087-0-00702900-1346225698_thumb.j
A lot easier on mine as it's just 2 bolts each side! :)
Had to put the springs on upside down as getting the bolts out to adjust camber is a bit of a hassle.
post-16087-0-72287000-1346225659_thumb.j
  • New Member
Still have mine at standard front height so have set it at max camber and after some measuring looks to be -2.8 to -3 camber. Was hoping for a little more than that so will look at lowering it a touch to gain some more.
Nice setup you have there :imsohappy:
  • Member For: 15y 3m 25d
mako track?
there is a bit of a drive day at the showgrounds on sunday, I'll be throwing the barge around.
  • New Member
mako track?
Yeah been going to the Mako Track....what's on this Sunday??? I know the auto spec is on in 3 weeks so will be going in that, would be keen to try it out sooner though.
just a little motorkhana day run by one of the ford clubs, might put mine in autospec but the valvesprings are shagged, see how it holds up this weekend.
I think all spots are taken for sunday, but maybe drop in and see if someone pulls out.
