5th Gear Crunches Who Has Had This Problem?
TURBO4LT
  • Gandalf the Grey, Maiar of Manwë and Varda, Team HgAg/Sneaky
  • Member For: 21y 7m 2d
Nearly 16,000 ks and I'm getting crunching when changing from 4th to 5th, especially at higher revs. :o
I'm about to ring the dealer ... this should be interesting. :nyaah:
  • Replies 57
  • Member For: 21y 8m 18d
I had my car in at the dealers for a service and the service manager actually rang me and said that the grinding (not so much of a crunch) into 5th gear was unacceptable and would order a new gearbox for me :thumbsup:
got to be happy with that :lol:
  • Forum Superhero
  • Member For: 21y 2m 5d
Have done 11,00klms no dramas (so far!) I always double the clutch when going into 5th :thumbsup:
I try to take it easy into 5th as I have heard of the troubles everyone's having. Then again it's hard to have a really fast gear change because the shift is so long, you have to be quite presice.
  • Used to work at the Ford Proving Ground!
  • Member For: 21y 11m 5d
My car is in the dealership as we speak getting a new gearbox fitted! I found that the clutch fluid got dirty really quick and then the gear changes got sh*tty, so I flushed the clutch fluid and then all was good for a week. Started being sh*tty to change gears again and checked the clutch fluid and was dirty again! Seems odd to me, maybe its a clutch throw out bearing and slave cyclinder problem! First off I found it very hard to get in reverse, the wife couldn't get it into reverse, then 3rd gear started catching on the way out to second or fourth, now the fifth gear crunching your all talking about started to happen and its very stiff to move around in neutral. Spoke to the dealer and within half an hour they had a new gearbox coming. Will see how it goes tonight! My car has only 7k on it and it isn't a T.
  • Member For: 21y 24d
After having a wrx :thumbsup: and being very sceptical about dealers and warranty it was a refreshing change to take my xr6t ute to Lane Ford in perth.
The service manager did not even drive the car and said that he would get it fixed. I am even getting a free loan car. ;) :banghead:
The story goes that they were originally replacing the whole box but now they are only replacing 5th gear.
I know that that dealership gets 2 cars per month. Now one would assume the manual / auto split is 50 / 50. The car has been out for about 15 months which means they have received 15 manual cars. Mine will be the sixth one they have had problems with. This means they are replacing about 40% of the boxes. One would suggest that would nearly constitute a recall.
cheers
brendon
  • Member For: 21y 7m 5d
The "common fault" develops initially with crunching on high-speed 4th to 5th changes, and then progresses to every use of 5th.
Mine has just started doing this. No other gear seems to be a problem as yet.
A change at relatively slow speeds is still OK. 10k on the clock.
Edited by 51XRT
  • Flaccid Member
  • Member For: 21y 8m 11d
After having a wrx :censored: and being very sceptical about dealers and warranty it was a refreshing change to take my xr6t ute to Lane Ford in perth.
The service manager did not even drive the car and said that he would get it fixed. I am even getting a free loan car. ;):censored:
cheers
brendon
Whats the point of a recall? What are they going to do to fix it?
replace a cr@p box that crunches with another box that is going to crunch later? I just change up slower now and when it finally sh!ts its self, I go in for a new box
  • 2 weeks later...
