TURBO4LT Member 1,533 Member For: 21y 4m 18d Gender: Male Location: NSW Posted 27/12/03 10:25 AM Share Posted 27/12/03 10:25 AM I think this has been spoken about before , does anyone know the actuall cause of this problem and is there a fix? My dealer said they are going to try and change the oil . Link to comment Share on other sites More sharing options...
Redhawk ....Time to lay this fairytale aside...... Donating Members 2,657 Member For: 21y 9m 26d Gender: Male Location: In the Ferry on the River Styx, not getting out just yet! Posted 27/12/03 12:59 PM Share Posted 27/12/03 12:59 PM Yes mate,Oil change won't help a bit, the dealer is giving you the run around. The problem is the brass they made the 5th gear synch ring out of is too soft and the crunching will only get worse.I got it in the Silverhawk and had a new gearbox fitted at 8000km.Fixed the problem OK and the replacement gearbox was better than the original.If you go faster the crunch gets worse, mine would be OK below 100kph but the faster you went the crunching got worse.See your dealer and demand a replacement gearbox. They have to get onto the manufacturer and they send a gearbox out and the dealer sends the old box back to them.Hope this helps. Link to comment Share on other sites More sharing options...
XR64T Are we there yet? Donating Members 703 Member For: 21y 3m 6d Gender: Male Location: Sydney, NSW Posted 27/12/03 01:56 PM Share Posted 27/12/03 01:56 PM I don't seem to have a crunching problem with 5th gear.Come to think of it, I don't seem to have a 5th gear How to I enable fifth, this would be quite handy on the freeway... :banghead: What if I solder a small animal to the ecu, will that help??? Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 4m 18d Gender: Male Location: NSW Posted 27/12/03 09:36 PM Author Share Posted 27/12/03 09:36 PM RedhawkThanks for the info , that's exactly what mine does . I have 9k on mine now and it started doing it a few weeks ago. Link to comment Share on other sites More sharing options...
CFlat Member 54 Member For: 21y 4m 17d Location: Canberra Posted 28/12/03 10:24 AM Share Posted 28/12/03 10:24 AM Oi folks,First gearbox started crunching into top at 12000km (initially above 120kph, then progressively worse 'til every change was bad). Second gearbox lasted about 600km (it was a shocker - poor selector "feel", tight in all gears and crunched from the second day. Got about 9000km on the third box and all seems well, 'cept now my brakes are shuddering!!!!!!!Ah well, all warranty stuff. CiaoCFlat Link to comment Share on other sites More sharing options...
Goose 00-XRG / 006-FPV Donating Members 530 Member For: 22y 1m Gender: Male Location: Brisbane, QLD Posted 28/12/03 10:27 AM Share Posted 28/12/03 10:27 AM Is this happening when you just shift from 4th into 5th normally???? buggerif I go from any other gear 2nd or 3rd to 5th it usually grinds.30,000klms on mine now Link to comment Share on other sites More sharing options...
Redhawk ....Time to lay this fairytale aside...... Donating Members 2,657 Member For: 21y 9m 26d Gender: Male Location: In the Ferry on the River Styx, not getting out just yet! Posted 28/12/03 01:30 PM Share Posted 28/12/03 01:30 PM Is this happening when you just shift from 4th into 5th normally???? buggerif I go from any other gear 2nd or 3rd to 5th it usually grinds.30,000klms on mine nowTry pushing down the left hand pedal all the way mate!!! :banghead: Works for me!!! :banghead: Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 4m 18d Gender: Male Location: NSW Posted 28/12/03 11:52 PM Author Share Posted 28/12/03 11:52 PM REDHAWKThanks I never thought of that . Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 4m 18d Gender: Male Location: NSW Posted 28/12/03 11:59 PM Author Share Posted 28/12/03 11:59 PM GooseMine only does it when shifting up into 5th and more so when speed is over 100km. Link to comment Share on other sites More sharing options...
CFlat Member 54 Member For: 21y 4m 17d Location: Canberra Posted 30/12/03 01:44 AM Share Posted 30/12/03 01:44 AM Oi,Bloke at the dealer said that Borg-Warner had mentioned that short-shifting (2nd to 5th or 3rd to 5th) had created some problems, and that it was not a good practice with these boxes - maybe because of the softer brass synchro ring??The "common fault" develops initially with crunching on high-speed 4th to 5th changes, and then progresses to every use of 5th.Once you notice a few dicky changes. you gonna get a free gearbox! I got three with mine so far! Now that's a bargain.CiaoCFlat Link to comment Share on other sites More sharing options...
