discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 4m 30d Gender: Male Location: Probably above atmospheric pressure Posted 24/08/12 04:30 AM Share Posted 24/08/12 04:30 AM Metal mesh covering spaced away from cooler? And add in a gap above it, put a small air scoop to force air down through Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/6/#findComment-1284323 Share on other sites More sharing options...
SPOOLAX Skids? Donating Members 975 Member For: 15y 11m 17d Gender: Male Location: Adelaide Posted 24/08/12 06:46 AM Share Posted 24/08/12 06:46 AM Whats the price for a rebuild from joe? Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/6/#findComment-1284402 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 7d Gender: Male Posted 24/08/12 06:55 AM Share Posted 24/08/12 06:55 AM Whats the price for a rebuild from joe?Depends what you want done and what shafts you want to use, best to call as I'm sure Joe can go through the costs with you Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/6/#findComment-1284408 Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 9m 30d Gender: Male Location: Sydney Posted 24/08/12 11:01 PM Share Posted 24/08/12 11:01 PM I'll definitely be getting that cooler done now.Like the fact that it doen't require the very long hoses required to mount on the front right bar.(I already have an engine oil cooler on my front left bar)Now have a dilemma.On my current ZF fluid, (which even though was changed in January this year), has done 5 full circuit days (3 at Wakefield (one at near 30deg), 1 at Marulan and 1 at Eastern Creek.)Will the ZF filter/fluid be fried and should I do a quick fluid/filter change before the September 19th track day where there will be a lot of 3rd to 4th changes?(I already have enough ZF fluid left over from a 20l bottle I bought from Motospecs last year)Fluid change only costs me around $200.Problem is, if I do change it, will it highlight and make the flaring worse on the change from 3rd to 4th due to the lower viscosity of the fresh oil? Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/6/#findComment-1284784 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 7d Gender: Male Posted 25/08/12 04:05 AM Share Posted 25/08/12 04:05 AM Pretty sure when the oil starts to breakdown it loses viscosity so the fresh oil can only help. Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/6/#findComment-1284911 Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 9m 30d Gender: Male Location: Sydney Posted 25/08/12 08:03 AM Share Posted 25/08/12 08:03 AM I thought the ZF oil would get thicker with a few track days, hence masking the flaring effect?I know when I changed the oil on a very old 4 speed auto once, the flaring increased as the fresh oil was a lot thinner.Just need a bandaid fix for my next track day. Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/6/#findComment-1285020 Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 9m 30d Gender: Male Location: Sydney Posted 27/08/12 09:22 PM Share Posted 27/08/12 09:22 PM I noticed another characteristic of my 170,000km+ ZF today. Not dropping into 2nd for quick overtaking when in per auto mode.Was cruising at 80km/h in PERFORMANCE auto (probably in 6th) when I went to overtake this car in a 100kmh zone near Cessnock.The car dropped back to what felt like 3rd with my foot flat, and I felt the revs were too low for a quick overtake. It stayed in 3rd for a good 2 seconds still with my foot planted, then suddenly slammed into second with an audible crunch, car went sideways before traction control took over.Is this the same worn clutch pack problem between my 3rd to 4th changes a redline on the track, or should I just do an oil/filter change?(I realize I am procrastinating over a full $rebuild$) Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/6/#findComment-1286152 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 2d Gender: Male Location: SE Melbourne Posted 27/08/12 10:26 PM Share Posted 27/08/12 10:26 PM Will the zf even go into second at 100ks? I thought it was 3rd. Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/6/#findComment-1286165 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 7d Gender: Male Posted 28/08/12 01:00 AM Share Posted 28/08/12 01:00 AM (edited) Yeah probably a bit fast for 2nd, when I used to drive in P mode I used to love coming out of the M5 east at princess hwy as I used to floor it up the exit at 80kph and it used to drop to 2nd and wheel spin all the way up the exit.I only drive in manual mode now as I dont want any violent kickdowns that may cause snappage of the input shaft.Now that I'm used to it I actually prefer driving in man mode. Edited 28/08/12 01:01 AM by rednose 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/6/#findComment-1286238 Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 9m 30d Gender: Male Location: Sydney Posted 28/08/12 01:36 AM Share Posted 28/08/12 01:36 AM I noticed another characteristic of my 170,000km+ ZF today. Not dropping into 2nd for quick overtaking when in per auto mode.Was cruising at 80km/h in PERFORMANCE auto (probably in 6th) when I went to overtake this car in a 100kmh zone near Cessnock.I was doing 80kmh Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/6/#findComment-1286251 Share on other sites More sharing options...
