discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 7d Gender: Male Location: Probably above atmospheric pressure Posted 20/08/12 05:04 AM Share Posted 20/08/12 05:04 AM But what if you are doing nuts in a carpark and want to get even more smoke going by shifting to 4th????hahaha. Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/4/#findComment-1281867 Share on other sites More sharing options...
mr_crust Member 44 Member For: 14y 5m 13d Gender: Male Location: Melbourne Posted 20/08/12 05:49 AM Author Share Posted 20/08/12 05:49 AM (edited) might just throw a smoke machine in the boot to smoke up car parks hahaha Edited 20/08/12 05:50 AM by mr_crust Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/4/#findComment-1281883 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 4d Gender: Male Posted 20/08/12 05:54 AM Share Posted 20/08/12 05:54 AM The mismatched wheels would definitely contribute to the problem however it may still have an internal issue... See how it goes I reckon Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/4/#findComment-1281885 Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 17y 2m 20d Gender: Male Location: Sydney Posted 20/08/12 06:47 AM Share Posted 20/08/12 06:47 AM (edited) Hmm I'm not entirely convinced that the wheel thing was the issue. Go for a 30 min drive and then try wot 3rd 4th. And get back to us.But hey if it was this uneven wheel thing then you have dodged a bullet somewhat and good win. Edited 20/08/12 06:48 AM by Vevapower Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/4/#findComment-1281905 Share on other sites More sharing options...
sambo29 Member 58 Member For: 13y 10m 17d Gender: Male Posted 20/08/12 06:50 AM Share Posted 20/08/12 06:50 AM Agree with vevapower but would be sad to see my old bf need a re build hope it is the wheel thing Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/4/#findComment-1281909 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 28d Gender: Male Location: Townsville Posted 20/08/12 07:29 AM Share Posted 20/08/12 07:29 AM You now need to get a tyre profile for the spare that is the same rolling diameter as the 19's you have on. I find that a 3% difference in rolling can cause this problem is mighty strange but hey, I'm no mechanic! Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/4/#findComment-1281943 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 3m 22d Posted 20/08/12 07:35 AM Share Posted 20/08/12 07:35 AM http://www.fordxr6turbo.com/forum/topic/74739-zf-issues-or-so-I-thought/page__hl__%2BrebuildTo sum it up, was slipping 3rd to 4th.Had 19's on front and 17's on rear.Put 19's back on the rear, problem appeared solved, but a month later the tranny needed clutch packs replaced. Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/4/#findComment-1281947 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 15d Gender: Male Posted 20/08/12 08:01 AM Share Posted 20/08/12 08:01 AM (edited) Reading the initial post you may be right as you say that when driving in manual it changes fine.But were you changing into 4th at WOT high up in the rev range?, as this would mean you are doing about 150 k/ph.This is where mine slips but if yours does not slip in man mode than it may have been the wheels.Theres only one way to find out, where is your nearest freeway.... Edited 20/08/12 08:03 AM by rednose Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/4/#findComment-1281960 Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 10m 6d Gender: Male Location: Sydney Posted 20/08/12 09:36 AM Share Posted 20/08/12 09:36 AM I have a bad feeling this is what is happening to my ZF.(Can't be too hard on it as it's done over a dozen circuit days and 175,000kms!)Change from 3rd to 4th often delays at full throttle on the circuit and find I have to back off a bit to get a smooth selection.Genuine ZF Oil, Larger heat exchanger, Coolant and ZFfilter changed every year or 45,000kms approx.Not found a need to join the "Milkshake Hysteria Wagon" with a Cooler. Have an engine oil cooler instead.Listen to change at the 10sec mark. It is now a lot worse and has an even longer, high rev duration period before selection 4th. Where do I get this fixed in Sydney and how much approx?Car has 350rwkw and a lot of torque on the small FG turbo and e85. Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/4/#findComment-1282021 Share on other sites More sharing options...
Timmy-XR6T Silver Donating Members 179 Member For: 15y 8m 18d Gender: Male Location: Sydney, Inner South Posted 20/08/12 09:41 AM Share Posted 20/08/12 09:41 AM (edited) On 20/08/2012 at 9:36 AM, nelsonian101 said: I have a bad feeling this is what is happening to my ZF.(Can't be too hard on it as it's done over a dozen circuit days and 175,000kms!)Change from 3rd to 4th often delays at full throttle on the circuit and find I have to back off a bit to get a smooth selection.Genuine ZF Oil, Larger heat exchanger, Coolant and ZFfilter changed every year or 45,000kms approx.Not found a need to join the "Milkshake Hysteria Wagon" with a Cooler. Have an engine oil cooler instead.Listen to change at the 10sec mark. It is now a lot worse and has an even longer, high rev duration period before selection 4th. Where do I get this fixed in Sydney and how much approx?Car has 350rwkw and a lot of torque on the small FG turbo and e85.not an expert here- but am thinking you need to tighten the camera up a bita couple of g's and it goes from front view to side view :sungum: as for your question, I'll leave it to the group ! Edited 20/08/12 09:41 AM by Timmy-XR6T Link to comment https://www.fordxr6turbo.com/forum/topic/81501-zf-6-speed-auto-not-changing-from-3rd-t-4th/page/4/#findComment-1282023 Share on other sites More sharing options...
