  • Member For: 13y 11m
Thanks Paulie,
So any recommendations on rebuild? Nizpro input shaft and 3000rpm high stall? Any places close to rockingham that does rebuild, Thoughts?
  • Member For: 16y 5m 4d
no prob mate.
probably best to send the box to xft (simon) or monsta torque (rob).
give them a call and discuss options. There are heaps of parts available for these boxes now.
  • GONE FULL WIZARD
  • Member For: 16y 3m 20d
Take it to XFT in Perth, Simon will sort you out easily and from what I hear may have some new tricks with the ZF.
No worries, I'll give Simon a call ASAP and see what he can do :) and organize a tow haha
Thanks allot
Ok so if anybody is interested, a complete rebuild with hardened internals and Nizpro billet input shaft, drive away is $4250... not really that bad :) .......just didn't need it to happen right now haha
Also I got told deka 80lb injectors and my 12psi actuator coming from rapid systems are s**t? what do you guys think?
And from what I told you already what am I missing to hit the 370kw at the wheels mark?
Thanks again :)
  • Member For: 14y 3m 8d
Just before you commit to the trans rebuild you could take a peek through the inspection plate where you do up the torque converter bolts and check the flex plate is still bolted to the engine and torque converter. Just give it a wriggle by hand to confirm or get someone to move the front pulley back and forth with a socket while you watch the flex plate :)
  • Throbbing Member
  • Member For: 16y 2m 21d
that's from xft? extra clutch packs and so on? standard stall? trans cooler?
Thanks again :)
surge tank with 044, e85 tune and valve springs
also dont forget to get your turbo housing ported.
Edited by Paulie2256
Riptide:
Thanks for that, I'll have to see what I can do :)
Bigkeels:
That price is from XFT, with clutch plates fully rebuilt and Nizpro input shaft. Standard stall I think, and I'll have to ask about the trans cooler coz from what I've been told I don't think it comes with one.......but he did say drive away so I should get more info from what I will be driving away with haha
Paulie:
Thanks again mate, I thought surge tank was a backup? As in when you were low on fuel you can't punch it too hard, which I don't on low fuel anyway. Is the Walbro 300 lt ph not enough?
Also is it still nesersary to change the valve springs, I though BF MK2 had typhoon springs?
BPT are doing the tune, should I get the 1.2K plenum upgrade? Will this help.
Regards
300lt ph is plenty but you still run a risk of fuel surge with a full tank. Its not required for power but it depends on how safe you want it to be.
pretty sure you wont need the plenum at 370 but it wont hurt.
and your springs will go soft trust me. better of putting crow springs in early and not worry about it down the track.
