  • Member For: 17y 5m 7d
Why did I say ABS system? ATM machine...? Anyway...
  • 2 weeks later...
  • Member For: 13y 6m 9d
Had the dealer look over it and they said they heard the noise and it was a sway bar, turns out it does it wven louder after whatever they have done to it!
I live 3 hours from the dealer I bought the car ao just taking it back and complaining isnt realy an option :/
Guess its somthing ill have to live with hey
  • Cruise Whore
  • Moderating Team
  • Member For: 19y 8m 26d
Any Ford dealer should honour the warranty. Try again somewhere else closer?
  • Inactive Members
  • Member For: 12y 8m 2d
Hey Mate,
Exactly the same problem for me with my FG xr6T
Have had it for about 1 month, Also get the clunk when starting the car and driving away.
There is NO WAY its the diff bushes, it is definately coming from the front/engine bay area. Only does it once, drive off slow after about 10-15 mtrs slow or fast it goes... "Clunk"
If it was an ABS self test then everycar would do it no?
Im gonna pop down to ford and leave it with them to work out under warrenty. I can tell you though. I will be getting a full 3rd party written inspection before it goes out of warrenty!
So, UWNTM3.. I feel your concern. I will re-post here after being to Ford.
  • Member For: 19y 2m 18d
Erm, every FG should do it. Mine does. And every other one I have been in does too.
That makes me feel a little but better!
But the clunk in the rear is peeing me right of
Feels like its got a solid rod in there for a shock
  • Member For: 12y 10m 8d
My G6ET does the same thing. Doesnt matter if I reverse or drive forward from taking off.
Only problem is ive had my car lowered on coil overs, so it may be diff bushes.
I was told it should be fine by my mechanic and its normal, but im like the rest of you, still not sure :/
  • Member For: 13y 14d
My fg is making the same clunk noise when taking off, doesn't matter how long I drive under 15kmh as soon as I go over "clunk". Doesn't happen again once moving unless I let the car sit for half a hour. Also put in my ssl and sssl and new shocks in on the weekend, I checked most things while at it but couldn't see anything
  • Member For: 13y 5m 21d
Clunk in rear sounds like diff bushes, I had my BF done when I got the car. Sweet as now, if you find out that it is diff bushes get the super pro comfort spec bushes they seem to last alot longer then factory bushes and dont have the noise of solid urethane ones.
Also, mine does the half a dozen tap things when I start the car too... Thought it might have been something to do with the ABS.
Edited by Falky100
