  • Member For: 14y 9m 24d
  • Gender: Not Telling
For those interested the algorithm to calculate power on a dyno, is based on the speed that the torque is produced. To clarify this a little further, power is based on how fast the work (torque) is done, and torque is based on how much work can be done. An example of this is the steam engine. It is capable of pulling massive weight, due to having much torque. But it doesn't produce much power, therefore it takes time to get it up to speed. So a car that is running a 1/4 mile is required to produce both torque and power, to obtain a fast time. It is torque that is required to get you off the line, but power to get you over it. Hopefully that makes some sense.
Cheers
Edited by Impellor
  • Member For: 18y 11m 17d
  On 15/08/2012 at 5:24 AM, ratter said:
Bels G6ET has done 319 with 12.5
Just for proof, theres a s light kick in the boost at peak kw to approx 12.8 psi
