  • Puff
  • Member For: 10y 2m 30d
What turbo etc are you running? What power goals are you looking for? Either way a set of 235's aren't going to hook up very well at legal speeds.
  • Bronze Donating Members
  • Member For: 11y 4m 25d
Stock 3582. Stock motor apart from valve springs. Full fuel system with turboside, Plaz plenum and cooler.
400+ on e85 and im happy. He said it'll go 430ish before it runs out of surge pump (044). He was happy to take it to 450+ if I had an extra pump.
My normal tyres are 275 nt05's so they are fine on the street. They just have trouble on the dyno hence the skid rims on.
  • Member For: 12y 2m 2d
235s are ok if the compound is good. I broke my tailshaft with 235 ar1s
  • Puff
B series or F?
I've used the ns2r in a 255 17 with a 120 compound and it still spun in second with an 18psi 98 tune.
275 radial slicks spun on the road in 3rd with an e85 tune.
I spose every car is a bit different.
  • Dropping a turd
  • Member For: 17y 6m 1d
Expand
Get him to throw in a singe pierberg before tuning.  044 junk and crap on E85.
  • Dropping a turd
Is your 044 on  relay with power from the battery.   If not after volt drop you may have issues when the electrical system is under load.   Maybe appear OK on the dyno.
Edited by arronm
The 044 and the intank 460 are on there own relays in the tray so they are getting the full 14.7 volts ish.
The surge is fed by the 460 so a bit of back pressure in the surge will help the 044 along. I will be upgrading the pump eventually with something better and quieter but it'll do the job for now
  On 10/09/2018 at 11:56 AM, Puffwagon said:
B series or F?
Fg. It was on the strip with freshly prepped track and very warm tyres. They still spin on street surfaces without a burn out yeh but so does everything I've used.
