  • Member For: 15y 8m 12d
Yeah it's free, I certainly have no need of it.
If you want it let me know, I can bring it to work or drop it off, just PM me.
  • Member For: 17y 7m 3d
Yeah was a bit of a joke, but RW is a good idea :)
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 18d
I bought a 7800N back when wireless-N was a 'proposed specification' (back in about 2009-10, I think..) and have been using it for both ADSL and NBN ever since. Never lived in a massive house so wireless was never an issue :spoton:
Yeah I went through just about every manufacturer (D-Link, Netcomm etc) until the Comms Engineer's said to to try Billion.
The iiNet provided kit for my NBN connection is a Technicolour branded unit, which I'll stick with for the time being and will probably upgrade when I get the new place, most houses I've looked at are FTTP, so I can use an ethernet connector instead of needing a VDSL port for the FTTB modem.
  • Site Developer
NBN FTTP terminates at a NTD (Network Termination Device) which the fibre connects to which you just run an ethernet cable (from a UNI-D port) to a WAN/External port on a router. The NTD acts as an endpoint that ISP's can control a UNI-D port remotely so you can just re-plug to one of the other UNI-D ports if you switch providers, for example. So you don't need a VDSL port (unless the building wiring is weird as fark).
I wanted to use the Billion ethernet port, but when the NBN techs turned up, they wired from NBN's connectors - I can never remember the term for the ceramic connectors telephone tech's wire between - to the phone ones and then you connect via VDSL port to your normal telephone socket.
I can take photo's of the downstairs distribution box to show what I mean when I get home, as far as I am aware, we are the first FTTB site in W.A.
Do a look-up on 227 Vincent Street, West Perth (LOC000033675925) and you will see one purple patch right smack bang in the map with nothing else around it even close to getting NBN.
http://www.nbnco.com.au/learn-about-the-nbn/rollout-map.html
This is why the Liberal's multi technology mix is not so affectionately known as Malcolm Turnbull's Mess in IT circles.  Why in god's name they decided buying Telstra's cr*ppy copper as well as forcing NBN Co' to pay for remediation works when Telstra had to pay the costs before just goes to show why bean counters should be shot if they even look in the direction of IT based projects.
I am really glad I don't have to deal with the budget's any more, some of the half ars*d rules accountants come up with, I'm sure it's because they need to justify their jobs.
