  • billet turbos and weathered engines dont mix
  • Member For: 13y 23d
Hahahahahahahahaha best post in a long time!
  • 2 months later...
  • Member For: 14y 2m 21d
Well got the Koni,s fitted today, had them adjusted to 1 full turn as suggested this would be a good start. Feels nice a planted, tried a quick run along a street that normally bottoms out the car but all good.
Thanks to Josh and the guys at Wholesale Penrith.
Next step is a Truetrack diff, got a price today for supply and fit @ $1700 (not at Wholesale suspension).
Thanks all for the earlier advice.
Not sure about fitting polly bushes, the Diff guy reckons you get a lot of noise through the car, he actually reckons you get a whine and to stay with the factory rubber.
Have you had the Super pro fitted?
  • Member For: 14y 2m 29d
I have every bush done in poly (super pro comfort spec) with bilstein's and the noise isn't too bad. Only notice it when radio is off. Highly recommend at least the diff bushes.
  • Member For: 14y 11d
That diff guy does know sh*t, bearly any difference from factory bushes. There are lots of guys on here with the comforts and swear by them.
Maybe slight increase in NVH, more like extra tyre noise really.
Put the factory ones back in and you will be pulling the diff out later replacing bushes again.
Fit superpro comforts and you are unlikely to have to drop the cradle again.
  • Member For: 17y 6m 21d
Yep go comforts. They are the ones with the "turbo spiral" sort of holes in them.
I had a solid Superpro diff bush in there and it was noisy as. With the comfort it's way better:
