Guest XR09 Guests Posted 12/08/12 04:09 AM Share Posted 12/08/12 04:09 AM With a decent suspension set up. And a guy doing the alighnment as the car stands and not too factory specs. You will find you get twice the life out of your front tyres.If your doing a lot of city driving, lots of 90 degree turns and reverse parking you will scrub the inners out of the front in no time at all.Also reccomend going a couple of psi at least over factory spec in the fromt tyres as well. Helps spread the load a bit when doing all the turning that really loads up and squishes the insides of the fronts Link to comment https://www.fordxr6turbo.com/forum/topic/81399-suspension-upgrade/page/2/#findComment-1278215 Share on other sites More sharing options...
PookeyMaster Donating Members 1,531 Member For: 14y 5m 24d Gender: Male Location: Parramatta, NSW Posted 12/08/12 05:38 AM Share Posted 12/08/12 05:38 AM Well, the Factory PSI is 38 all round normal and 42 for load so what pressures do you recommend? Link to comment https://www.fordxr6turbo.com/forum/topic/81399-suspension-upgrade/page/2/#findComment-1278241 Share on other sites More sharing options...
tradey Member 72 Member For: 16y 3m 21d Posted 15/08/12 11:34 AM Share Posted 15/08/12 11:34 AM Hey bullsh*t kroozin Go the billys with H&R coils none of this kings sh*t on ya moms carShe likes cars that handle and even with 270 at the wheels her car blows off softies with 400 kwAdmit it does her car blow you off or not Link to comment https://www.fordxr6turbo.com/forum/topic/81399-suspension-upgrade/page/2/#findComment-1279842 Share on other sites More sharing options...
spinr33 Donating Members 964 Member For: 13y 9m 26d Posted 15/08/12 11:52 AM Share Posted 15/08/12 11:52 AM Aren't the koni damper adjustable where as the bilstein aren't adjustable at all ? Or the ones your are susgesting aren't any adjustability is better then none koni all the way Link to comment https://www.fordxr6turbo.com/forum/topic/81399-suspension-upgrade/page/2/#findComment-1279849 Share on other sites More sharing options...
wa g6et Member 657 Member For: 14y 9d Gender: Male Location: Perth NOR Posted 15/08/12 12:07 PM Share Posted 15/08/12 12:07 PM The Bilsteims aren't adjustable, the Konis are but off the car. Link to comment https://www.fordxr6turbo.com/forum/topic/81399-suspension-upgrade/page/2/#findComment-1279853 Share on other sites More sharing options...
spinr33 Donating Members 964 Member For: 13y 9m 26d Posted 15/08/12 12:26 PM Share Posted 15/08/12 12:26 PM Are you sure the konis have to be taken off the car to adjust ? They don't have a dial etc on the side or down the middle Link to comment https://www.fordxr6turbo.com/forum/topic/81399-suspension-upgrade/page/2/#findComment-1279856 Share on other sites More sharing options...
tradey Member 72 Member For: 16y 3m 21d Posted 15/08/12 09:31 PM Share Posted 15/08/12 09:31 PM Go the billys mate Had both They spend a motza on getting there set up right and in balance front to rear etc Im not sure im that bright ,that I have access to a tack for fine tunning , that id get it any betterMy wifes car handles brilliantly and if you like a car that goes round corners you dont like driving a boat Its one compromise or another make your choices and go with it Link to comment https://www.fordxr6turbo.com/forum/topic/81399-suspension-upgrade/page/2/#findComment-1279932 Share on other sites More sharing options...
wa g6et Member 657 Member For: 14y 9d Gender: Male Location: Perth NOR Posted 15/08/12 09:43 PM Share Posted 15/08/12 09:43 PM On 15/08/2012 at 12:26 PM, spinr33 said: Are you sure the konis have to be taken off the car to adjust ? They don't have a dial etc on the side or down the middleKoni reds need to come off to be adjusted. No dial on the side. Adjustment done by fully inserting the insert and twisting should slide thru 6 settings. Really only helps extend like of the shock. Link to comment https://www.fordxr6turbo.com/forum/topic/81399-suspension-upgrade/page/2/#findComment-1279935 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m 22d Gender: Male Location: Sydney Posted 15/08/12 11:23 PM Share Posted 15/08/12 11:23 PM (edited) On 15/08/2012 at 11:34 AM, tradey said: Hey bullsh*t kroozinGo the billys with H&R coils none of this kings sh*t on ya moms carShe likes cars that handle and even with 270 at the wheels her car blows off softies with 400 kwAdmit it does her car blow you off or not Edited 15/08/12 11:23 PM by Kroozin 2 Link to comment https://www.fordxr6turbo.com/forum/topic/81399-suspension-upgrade/page/2/#findComment-1279947 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 5d Gender: Male Location: SW Sydney Posted 15/08/12 11:41 PM Share Posted 15/08/12 11:41 PM ^^^ LOL Link to comment https://www.fordxr6turbo.com/forum/topic/81399-suspension-upgrade/page/2/#findComment-1279951 Share on other sites More sharing options...
