lee91g Member 21 Member For: 15y 3m 21d Posted 11/08/12 09:58 AM Share Posted 11/08/12 09:58 AM Hey guys,Are there many people out there that have changed the front calipers over for the 4 pot front brembos? If so have u been happy with this or moved up to the full 6/4 setup. Also is the standard fpv rear brakes the same as the bf xr6t caliper?Thanks for responses in advance Link to comment https://www.fordxr6turbo.com/forum/topic/81395-brembo-4-pot-upgrade/ Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 8m 27d Gender: Male Location: Newcastle Posted 11/08/12 10:43 PM Share Posted 11/08/12 10:43 PM Although I can't comment on upgrading on the same car I can tell you that upgrading from an XR6T (slotted 4000's with pads) to a GT with 4 pot fronts was a big improvement. I was considering upgrading my GT to the 6/4 setup but for what I'm using my car for (spirited street use) the current setup is proving quite capable.The FPV rear brakes are diffferent to the rear XR. Larger caliper and rotor.Benny. Link to comment https://www.fordxr6turbo.com/forum/topic/81395-brembo-4-pot-upgrade/#findComment-1278117 Share on other sites More sharing options...
lee91g Member 21 Member For: 15y 3m 21d Posted 12/08/12 02:07 AM Author Share Posted 12/08/12 02:07 AM Thanks for getting back benny, glad your loving your brakes, makes me more inclined to go the cheaper route since I can't see myself tracking it, even though I'd like to I haven't made the time in the 2 years I've had it.. LolI could be wrong but I've been looking into it a bit on the web this morning and found that gt/typhoon and bf can all use rda505 which are 303mm diameter so can anyone confirm with different sizes or something that the discs are different? Also if the caliper is different how so? Link to comment https://www.fordxr6turbo.com/forum/topic/81395-brembo-4-pot-upgrade/#findComment-1278156 Share on other sites More sharing options...
MX Dave Donating Members 545 Member For: 14y 27d Gender: Male Posted 12/08/12 02:58 AM Share Posted 12/08/12 02:58 AM Twin piston rear calliper instead of a single I believe. PBR item Link to comment https://www.fordxr6turbo.com/forum/topic/81395-brembo-4-pot-upgrade/#findComment-1278183 Share on other sites More sharing options...
AirStrike Donating Members 387 Member For: 16y 5m 11d Gender: Male Posted 12/08/12 03:17 AM Share Posted 12/08/12 03:17 AM It's still a single piston caliper but a different style, also the rotors are vented rather then solid. Link to comment https://www.fordxr6turbo.com/forum/topic/81395-brembo-4-pot-upgrade/#findComment-1278195 Share on other sites More sharing options...
MX Dave Donating Members 545 Member For: 14y 27d Gender: Male Posted 12/08/12 03:20 AM Share Posted 12/08/12 03:20 AM There you go^ I think I was thinking of FG cop cars Link to comment https://www.fordxr6turbo.com/forum/topic/81395-brembo-4-pot-upgrade/#findComment-1278198 Share on other sites More sharing options...
knoles Donating Members 390 Member For: 14y 1m 17d Gender: Male Location: Port Hedland Posted 13/08/12 12:52 AM Share Posted 13/08/12 12:52 AM I have a bf foon with 4 potters, my missus has a bf xr6 and the difference is so great even she can tell. Much prefers my car. Link to comment https://www.fordxr6turbo.com/forum/topic/81395-brembo-4-pot-upgrade/#findComment-1278561 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 10d Gender: Male Location: Perth Posted 13/08/12 02:22 AM Share Posted 13/08/12 02:22 AM ^ this, I went from BA/F premium pbr's to Brembo 4 pot front and rears and the difference is night and day. The car was scary under hard braking before and felt very unbalanced front to rear, not so with the 4potters. I will say they can be quite graby when cold depending on your pad choice. Link to comment https://www.fordxr6turbo.com/forum/topic/81395-brembo-4-pot-upgrade/#findComment-1278588 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 8m 14d Gender: Male Location: Zombie Birdhouse Posted 13/08/12 02:27 AM Share Posted 13/08/12 02:27 AM recommend Bendix ultimate Road, Street Track padsAlso get slotted DBA rotors a I managed to crack the factory slotted and cross drilled Link to comment https://www.fordxr6turbo.com/forum/topic/81395-brembo-4-pot-upgrade/#findComment-1278591 Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 10m 8d Gender: Male Location: Sydney Posted 14/08/12 01:26 AM Share Posted 14/08/12 01:26 AM I upgraded to 4 pot Brembos shortly after I bought my FGXR6T in July 2008. 15/20 full circuit days later, still going strong and I work them VERY hard now with slicks at the front and they get HOT!I swap the front pads for track day. Use standard Brembo pads for street.Have used SBS Dual Carbon Race pads with them, Endless PC35 Race pads, and now Project Mu H16 03 Race Only pads.Have destroyed 2 lots of DBA4000 slotted 355mm rotors and onto a 2nd set of 5000's with T3's. Calipers still fine and I recommend them considering what they have gone through on my car which has also done 175,000kms too!Dust seals burnt off but brakes still work fine. I also have the rear Territory upgrade with bigger PBR single piston rears and ventilated 328mm rotors.I cut slots in the front of the front wheel arch to aid cooling and both foglights are removed.Make sure your wheels clear them.http://www.fordforums.com.au/showthread.php?t=11310061I recommend fresh AP Racing DOT 5.1 for street and track. Link to comment https://www.fordxr6turbo.com/forum/topic/81395-brembo-4-pot-upgrade/#findComment-1279081 Share on other sites More sharing options...
