The What's Pi$$Ing You Off Thread
EFSIX
  • billet turbos and weathered engines dont mix
  • Member For: 12y 9m 8d
Cause it needs a new gasket, a stud too. Short of pulling the turbo off down there it needs to be at home. But I guess I could get away with it
What size is the turbo manifold stud? One is completely gone... The one that bolts the rear housing to the log manifold
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m 19d
Ford didn't put a gasket in there, neither should you!
The turbo will stay on, just drive it home and get new studs/nuts. (some locking nuts, ideally, so it doesn't occur again).
The ones you want are M10x1.5 at the manifold end and M10x1.25 at the turbo side.
These ->
http://www.ebay.com.au/itm/TURBO-EXHAUST-STUD-NUT-SET-M10-X-1-25-M10-X-1-5-4-PACK-/170532913066?pt=AU_Car_Parts_Accessories&hash=item27b48dbfaa#ht_1118wt_905
With these locking nuts ->
http://gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=1281&category_id=219&option=com_virtuemart&Itemid=101
Edited by k31th
Mate it sounds like a tractor and has zero power haha. Well I have a new gasket on order, must have been put on with the GTX
  • Site Developer
Why... that's anybody's guess... If I were to take a guess, I'd say the turbo flows fine without one and it wasn't worth the coin to put one in there.
It is indeed just a standard single opening T3 flange.
  • Member For: 11y 4m
Just had a peek at mine, there is definitely something there, looks around 0.2/0.3mm thick, same as the turbo flange gasket (which looks a little black around some parts) so I might need to check the tension soon
Moving back on topic, WPMO, I still can't find any reason for only getting 3.7psi, no leaks, IC pipes are good and no codes.
My next step is too bypass the solenoid and technically that should lower the boost to 3psi, telling me the solenoid is working. Then I'm stumped
These ->
Thanks mate helps a lot. Any reason everyone just doesn't use 10x1.5mm threaded studs and a bolt to dodgy it up just to get her home?
  • Site Developer
The 1.25mm thread has a better clamping pressure and torque application due to the nut sitting slightly closer to the surface.
Ahhh should have used my brain for that one haha^ cheers
