OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 2m Gender: Male Location: Western Sydney Posted 24/12/16 08:04 AM Share Posted 24/12/16 08:04 AM Pretty sure jet could chime in here but if that's your main board you've got bigger problems. No light circuit or RCDs? Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1979/#findComment-1626259 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m Gender: Male Location: Adelaide Posted 24/12/16 08:07 AM Share Posted 24/12/16 08:07 AM Pixy you just got "Proper" FHUCKED IN THE ARSE. They have flat out skimped on the size of the wiring and have not met the standard minimum requirements, how can I tell you ask ? Well the tell tail signs are at the bottom of the fusebox you can see where the active conductor has got so hot its basically turned into a heater element just like on your toaster and you can clearly see the Breaker is sufficient at 32A cabling is the most expensive part of any household electrical installation you can add massive % to a small electrical company's bottom line by pushing the limitations and installation methods on "Derating" cables but when you push the industry standards ( there for a bloody good reason ) you run the clear risk of burning a house to the ground and killing people what you do from here will get messy as all chit ! if you call the technical regulators they WILL shut off all electrical supply to your house and WILL NOT allow supply back on until the whole house has been inspected ... up side is it will be checked by a third party and stringently !! Down side is it can take AGES AND AGES especially at this time of the year and you won't be able to live without power obviously, costs associated can be sued against but again you'll be out of pocked for a while and court costs and time will suck initially the electrician/company can be fined and or loose their license due to failure to comply with a COC they would of singed off on you're just about to have another super crap time in you're life ... merry christmas dude 2 Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1979/#findComment-1626261 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 12d Gender: Not Telling Location: Radioactive wasteland Posted 24/12/16 08:21 AM Share Posted 24/12/16 08:21 AM If you need a hand with anything azza just gimme a bell. I'm only up the road. Even if it's just for a beer. A problem told is a problem solved. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1979/#findComment-1626263 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 6m 3d Gender: Not Telling Posted 24/12/16 08:45 AM Share Posted 24/12/16 08:45 AM if the electrician stuffed that up I'd hate to see your comms wiring..... Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1979/#findComment-1626264 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 12d Gender: Not Telling Location: Radioactive wasteland Posted 24/12/16 08:59 AM Share Posted 24/12/16 08:59 AM It looks like your amp wiring Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1979/#findComment-1626266 Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 8y 10m 17d Posted 24/12/16 12:13 PM Share Posted 24/12/16 12:13 PM 5 hours ago, Pixy Angel said: Well not happy again but that's pretty much my whole life ATM. Put the A/C on and about hour in no A/C. went and check main circuit board to find it has burnt out and close enough it could have burnt the house down................Fark Me! Also something..........farking over it! What the fark? 4 hours ago, OZYWALKER said: Pretty sure jet could chime in here but if that's your main board you've got bigger problems. No light circuit or RCDs? This 4 hours ago, JETURBO said: Pixy you just got "Proper" FHUCKED IN THE ARSE. They have flat out skimped on the size of the wiring and have not met the standard minimum requirements, how can I tell you ask ? Well the tell tail signs are at the bottom of the fusebox you can see where the active conductor has got so hot its basically turned into a heater element just like on your toaster and you can clearly see the Breaker is sufficient at 32A cabling is the most expensive part of any household electrical installation you can add massive % to a small electrical company's bottom line by pushing the limitations and installation methods on "Derating" cables but when you push the industry standards ( there for a bloody good reason ) you run the clear risk of burning a house to the ground and killing people what you do from here will get messy as all chit ! if you call the technical regulators they WILL shut off all electrical supply to your house and WILL NOT allow supply back on until the whole house has been inspected ... up side is it will be checked by a third party and stringently !! Down side is it can take AGES AND AGES especially at this time of the year and you won't be able to live without power obviously, costs associated can be sued against but again you'll be out of pocked for a while and court costs and time will suck initially the electrician/company can be fined and or loose their license due to failure to comply with a COC they would of singed off on you're just about to have another super crap time in you're life ... merry christmas dude And this. Your circuitry is extremely farked. Houses needs several circuits and to be split for lighting fixtures and usually broken down into several areas due to load factors on each circuit. Surely there is no way that got passed but jet is right you are going to be in for a world of hurt at a bad time of year. If you need anything man dont hesitate to ask. Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1979/#findComment-1626276 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m Gender: Male Location: Adelaide Posted 24/12/16 12:30 PM Share Posted 24/12/16 12:30 PM That won't be the main board, in a big domestic situation it's common to have two ( MSB and SSB ) even though its a sub the first breaker has to be labeled "Main switch" and isolate that actual board the main ( MSB ) will be with the meters and the sub is common to be half way through the house or closer to a pool area with a decent demand for pumps and obviously AC units the chitter to this situation is the cable may be destroyed all the way through and will need a full replacement 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1979/#findComment-1626277 Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 8y 10m 17d Posted 24/12/16 12:39 PM Share Posted 24/12/16 12:39 PM I hope you're right for pixys sake coz that sh*t is faked up if there isnt a second set of breakers..either way it needs to be reported and the builder called to get the peanut of electrician back asap Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1979/#findComment-1626278 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m 4d Gender: Male Location: Perth Posted 24/12/16 12:50 PM Share Posted 24/12/16 12:50 PM (edited) 32A should be min 4mm2. Could be a bad connection at the breaker. AC Feed should be at the bottom which is the burnt region Edited 24/12/16 12:54 PM by arronm 2 Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1979/#findComment-1626280 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 5m 2d Gender: Not Telling Posted 24/12/16 01:14 PM Share Posted 24/12/16 01:14 PM This is not the main board obviously. There will be a main board with the majority of the house wired through that. If necessary it can be reported later but Jet wasn't kidding when he said Pixies power will be turned off. If you call the local power network to report this issue, such as sa power for example, the main fuses to the street will be pulled within the hour and not replaced until the problem is rectified. Don't do this unless you want no power as of tonight. This clearly is not a suitable solution at this stage. Call the builder or elec and explain the situation and give them a couple of days to come out and fix it. Just remember if you act like an angry carnt people will delay helping you no matter how right or justified you are. It's not the end of the world to go without aircon for a while. At least there is a pool to cool off in. If you're handy and know how not to die when playing with this stuff then you could open the box and fix it yourself, providing that it is a short piece of wire in the box that burnt rather than a wire coming from a phase in the main board. If you don't know what you're doing or unsure of yourself then don't touch it. I know it sucks to have things go wrong but now is the time to put yours and your families happiness first and enjoy your xmas day! Look on the bright side, (no pun intended) at least the house didn't catch on fire! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1979/#findComment-1626285 Share on other sites More sharing options...
