  • Member For: 12y 1m 25d
  On 16/05/2016 at 5:23 AM, -Stever- said:
Yeah those input shafts are like $2k - LOL.  Luke was looking at some overseas part as an in between spec I think?
All clear now, I was just confused why you were talking about stock parts and mentioning $5k prices.  No need to buy a new (stock) box unless it's milkshaked.  Also buying input shaft and flexplate upgrades for a tuned T but leaving the rest stock will only get you a worn out stock box that needs a rebuild again.
Mine has been upgraded in terms of flex plate and internals when I rattled the flex plate off at the drags, but retains stock input shaft since I had a factory heat treated one that "if you haven't broken it yet, you won't break it".  Done me well so far!
What'd xft slug you mate? Pm if you want
  • Member For: 17y 4m 27d
$3k.  Stage 2 internals which from what I recall as a noob is clutch packs and machining pistons down to fit more in?  Flex plate I forget the brand... whatever XFT use.  Atomic or Nizpro or something.  Think I saved on labour a bit coz I'm a mad khunt but no hard numbers to pass on.  Just asked him to rebuild it "so I don't have to worry about it again".
  • To Loud
  • Member For: 13y 4m 21d
Can you spot the problem?
 This was early in the morning and 15 degrees outside.
No it has nothing to do with the coolant temp either.
Fark this is pissing me off soo much.
  • To Loud
hahaha, the car never goes past 5500. I keep it as far away from that as possible.
There has been 1 or 2 times where it may have reached 6000, but that was by accident.
No limiter bashing either.
Top left graph might steer you in the right direction.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 10d
stock boost for a BAXR6T? your car isn't supposed to make stock BA XR6T boost, I guess?
  • To Loud
nah mate, no split inter cooler pipe. Turbo is on Crack.
Yes that is using Torque PRO(paid version).
I have this bastard which I paid $200 for and it is half the price now.
I suggest you order this one because it turns off when the car turns off and does not drain the battery.
https://www.scantool.net/obdlink-mxbt/
f*ck me, it is even cheaper now. Maybe I should order another one for the Mrs' car.
Edited by masda74
