The What's Pi$$Ing You Off Thread
EFSIX
  • Bronze Donating Members
  • Member For: 11y 10m 25d
I just read that on google as well keify.......also found
Is a professional doctorate the same as a PhD? Both confer the title "Dr" on a successful candidate, but the two qualifications are not thesame. A PhD is a research based doctoral programme which usually involves little or no taught element* and is usually academic in nature.
from http://www.findaprofessionaldoctorate.com/advice/
  • Member For: 15y 2m 16d
The "Doctorate" is part of a PhD, or any other "Doctoral" level degree, for that matter.
The "Doctorate" by itself is not a degree. It must be combined with something else (most often research, but can be various other things) to be considered a degree of qualification.
correct, a doctorate could be by research or course work, but still a doctorate degree (engineering etc) is not the same as a PhD, there is quite a difference in requirements, breadth of research etc.
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m 22d
See the word "professional" before doctorate? It's another type of "Doctorate" level degree of which a PhD is just one type (specifically research into a new area, usually, but it depends on the tertiary academic institution). A "professional" Doctorate could be specific to a known area of knowledge with continued academic excellence.
Edited by k31th
do you have either a doctorate or a Phd ?
  • Site Developer
No, but I don't know how that is relevant.
I know a lot of academics who have all sorts of doctorate level degrees. I was also offered by my university to do a PhD but I declined.
good, then you should realize then that, which is all I have been saying, In Australia, in both research and academia, the ranking (if you like) is masters, doctorate, phd. Do professional doctorate degree, and that bit of paper at the end says doctorate NOT PhD. they are separate degrees, all I said in the beginning was a professional doctorate is not a PhD (because it isn`t), and you said `your kidding....` time to move on I think
  • Site Developer
A doctorate isn`t a PhD, it goes Masters, Doctorate...then PhD
You said this, which is wrong. For the over-arching definitions of "degree qualifications" it goes bachelor, masters, doctorate.
There are many sub-classifications of each level and a PhD is just one type of doctorate level degree.
You don't "get a doctorate" then "get a PhD" unless they are completely separate qualifications.
  • Member For: 9y 10m 9d
Used to work in a job that needed to know quals a bit:
http://www.aqf.edu.au
P63 of the handbook on this site - PhD is one type of doctoral degree, rather than being higher than a doctoral degree.
