The What's Pi$$Ing You Off Thread
EFSIX
  • Formerly EGOBFXR6
  • Member For: 16y 11m 29d
When your pride and joy gets rear ended...
Edited by NVT
  • Member For: 17y 2m 10d
Oh dear....pics NVT/Dan?
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 9m 24d
Didn't say you can't use it, just don't use it anywhere near heat sources (engines/exhaust/coolant lines etc).
I'd still crimp in that situation of that video, personally... Ironically, it says "crimped insufficiently" in the description of the recall fault haha, just sufficiently crimp it to repair, you'd think.
  • Member For: 11y 2m 14d
Look keif I wont tell you how puters/programming(and gearboxes.....) works if you dont tell me how electronics works lol. Crimps are fine for terminating a cable or maybe joining 1 or 2 but 5? No..will always get a higher resistance than solder as a crimp simply does not penetrate. Solder is also fine with heat, takes quite hot direct contact to get it to flow, once heat shrunk with a heat shrink that contains a sealent compound its very unlikley to fail. Fire rated heatshrink that contains a resin is also avalible that will take a direct toasting for 2+hrs... Seen soldered 3 phase connections on large fans in bloody harsh environments supporting 80+ amps(start up) no worries. Better than a cumbersome house hold connector anyway..
I dont know why I bothered writing any of that given you still maintain crimps are the go even after watching a video on a saftey recall for my exact problem that says otherwise.......
Edited by barnz
  • Site Developer
so, the bottom line is... use the product that's appropriate for the scenario/environment? glad we agree on that :)
