OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 3d Gender: Male Location: Western Sydney Posted 11/03/15 11:18 AM Share Posted 11/03/15 11:18 AM Fuel leaks Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1298/#findComment-1534259 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 10d Gender: Male Location: Probably above atmospheric pressure Posted 11/03/15 11:48 AM Share Posted 11/03/15 11:48 AM On 11/03/2015 at 11:15 AM, PhilMeUp said: Check/tighten the drain bolt?Might give it a look later on, if it's as simple as that I'll be stoked Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1298/#findComment-1534266 Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 9m 18d Gender: Male Location: Perth, Western Australia Posted 11/03/15 12:09 PM Share Posted 11/03/15 12:09 PM On 11/03/2015 at 11:48 AM, -Stever- said: Might give it a look later on, if it's as simple as that I'll be stokedIt'll be a 15mm head.Could be a stuffed washer. Good excuse to do a diff oil change. Make sure that you can remove the fill bolt before you drain it - pretty sure it's a 10mm allen key. Bondhaus make a nice long one that gives good leverage.If you really had to, you could remove the drain bolt, bold a thumb over the hole and fit a new washer to the bolt with your free hand.Diff oil: I use Penrite Pro Gear 80-140. It's expensive and heavy duty, but does the job well and doesn't require any additives. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1298/#findComment-1534271 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 10d Gender: Male Location: Probably above atmospheric pressure Posted 11/03/15 12:15 PM Share Posted 11/03/15 12:15 PM On 11/03/2015 at 12:09 PM, PhilMeUp said: Good excuse to upgrade the diff.Good thinking! Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1298/#findComment-1534274 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 10d Gender: Male Location: Probably above atmospheric pressure Posted 11/03/15 01:59 PM Share Posted 11/03/15 01:59 PM Can't see a washer between the drain bolt and the diff cover, should there be one? Was last serviced a while ago now, maybe 20-30 thousand! Hard to recall.Was surprised how hot it was even after sitting for a couple of hours.Two of the other bolts I could access were a little loose, not much though. Tightened them up pretty good and degreased the area so I'll check for drips tomorrow (maybe). Also I have the plain filler bolt it seems, which is too big for any of my sockets. Forgot to measure it but I know there are multiple sizes. Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1298/#findComment-1534290 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 11d Gender: Male Location: Perth Posted 11/03/15 02:00 PM Share Posted 11/03/15 02:00 PM That's the cover leaking mate. Cradle out to fix that. Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1298/#findComment-1534291 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 10d Gender: Male Location: Probably above atmospheric pressure Posted 11/03/15 02:23 PM Share Posted 11/03/15 02:23 PM (edited) *sniff*What's that you said? Cradle out for new diff?(I wish)Could it be an axle seal? Just doing some googling. Guess we can have a look on the hoist. I'll buy some oil beforehand. Edited 11/03/15 02:32 PM by -Stever- Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1298/#findComment-1534300 Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 9m 18d Gender: Male Location: Perth, Western Australia Posted 11/03/15 05:43 PM Share Posted 11/03/15 05:43 PM On 11/03/2015 at 2:00 PM, Ralph Wiggum said: That's the cover leaking mate. Cradle out to fix that.I knew there's a reason why I've got utes and wagons... leaf spring back ends = easy to maintain. Taxis - cheap and easy to maintain takes priority over comfort around corners. Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1298/#findComment-1534306 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 5m 21d Gender: Male Location: Dé·jà vu Posted 11/03/15 06:47 PM Share Posted 11/03/15 06:47 PM On 11/03/2015 at 8:20 AM, BenDoCo said: You own the friggen letterbox ya fool.*Giggle. Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1298/#findComment-1534310 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 3d Gender: Male Location: Adelaide Posted 11/03/15 08:25 PM Share Posted 11/03/15 08:25 PM But I don't have to use it Link to comment https://www.fordxr6turbo.com/forum/topic/81368-the-whats-piing-you-off-thread/page/1298/#findComment-1534316 Share on other sites More sharing options...
