genuine honest person Member 2,769 Member For: 11y 27d Gender: Male Location: near brisbane Posted 10/08/14 02:27 AM Share Posted 10/08/14 02:27 AM nizpro cooler and valve springs , bigger injectors , hot side piping ,rebuild turbo (ba) with a 6 plus 6 wheel , bigger fuel pump , 3.9 diff with a true track ,rebuild btr with au parts ,etc ?no wheel spin at all ,used semi slicks achilles 123 . 235 45 17 the engine that I have (out of a sedan used to run a 12.344 at willowbank with a stuffed box and standard turbo that was on the way out . and only the hot side turbo standard rubber hose was fitted as well Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 11y 11m 29d Gender: Male Location: Perth Posted 10/08/14 02:40 AM Share Posted 10/08/14 02:40 AM (edited) Devo at that time for the power... Something must be up. No wheel spin? Were u stalling it up?Oh just read semi slicks I guess that helps on the wheel spin front! Edited 10/08/14 02:41 AM by Lennox Link to comment Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 27d Gender: Male Location: near brisbane Posted 10/08/14 02:47 AM Share Posted 10/08/14 02:47 AM I could only get it to stall up to about 2200 rpm .but the turbo only starts to pull at about 3300 rpm or even higher 3500 rpm. Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 11y 11m 29d Gender: Male Location: Perth Posted 10/08/14 02:48 AM Share Posted 10/08/14 02:48 AM (edited) Why only 2200? Wheels spin if more?Did u leave tray off for the drags? Looks mad like that! Edited 10/08/14 02:50 AM by Lennox 1 Link to comment Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 27d Gender: Male Location: near brisbane Posted 10/08/14 02:52 AM Share Posted 10/08/14 02:52 AM 869 nm at 3,323 rpm there it is . and had to change gears at about 5500 rpm .it just felt real lazy at high rpm ,especially going over the line in 3 gear at about 5600 rpm .I did one run and changed it into 4 th but did not help Why only 2200? Wheels spin if more?Did u leave tray off for the drags? Looks mad like that!it just would not rev up more (no wheel spin ) the engine just has no torque down low ,midd range great ,top end no good ? Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 11m 30d Gender: Male Location: Frankston, 3199 Posted 10/08/14 02:57 AM Share Posted 10/08/14 02:57 AM I'm probably wrong (usually are) but from the sheet above I'd be suggesting the boost isn't coming on til much later - closer to 4k? 1 Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 11y 11m 29d Gender: Male Location: Perth Posted 10/08/14 03:20 AM Share Posted 10/08/14 03:20 AM I reckon you need a hi stall so You can launch where the boost is 1 Link to comment Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 27d Gender: Male Location: near brisbane Posted 10/08/14 03:40 AM Share Posted 10/08/14 03:40 AM (edited) still have to be able to tow a camper trailer .that's why I can not fit a stall .might have to change to a standard turbo wheel I'm probably wrong (usually are) but from the sheet above I'd be suggesting the boost isn't coming on til much later - closer to 4k?that's probably right mate .it takes ages after I take of to come on boost , mate .is that just a sh*t tune or what ?they only spend about 2 hours tuning it if I include there lunch breaks .I said to them that it had 327 rwkw before I done some mods to it but they did not want to put there name to the tune if the engine blows .so this is even worse ,as it does not perform at all .when I phoned them last friday and asked if they would give it another try to get more out of it .Lee said that's all it got or they would have given it more . Edited 10/08/14 08:03 AM by Dagabond Link to comment Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 7m 7d Gender: Male Location: Brisbane Posted 10/08/14 04:20 AM Share Posted 10/08/14 04:20 AM GunnaYou might have to bite the bullit and get it tuned properly. 2 Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 9m 20d Gender: Male Location: Central Coast Posted 10/08/14 04:21 AM Share Posted 10/08/14 04:21 AM Your turbo wheel will be spooling quicker than standard Probably in the tune bud 1 Link to comment Share on other sites More sharing options...
