  • Member For: 14y 9m 19d
  • Gender: Not Telling
  On 10/08/2012 at 11:21 AM, JETSNOT said:
impellor that's bullsh*t unless your car has been on his dyno b4
Is that right? He was happy for me to put it in my signature as well. I guess your not privy to everything hey.
Cheers
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 8d
yeh spose your right he does genericly tune my car in the car park, just to far to get it onto the dyno
Edited by RHR
  • Member For: 17y 1m 19d
Another case of someone just listening to what they want to hear.
I rate generic tunes actually much cheaper, the best ones are 23psi in the mid jobbies
  • Like 2
  • Member For: 18y 11m 12d
  On 10/08/2012 at 11:30 AM, TheOne said:
Thanks for all your info ratter, it's much appreciated. Just wondering if you have seen any cases where a generic tune hasn't caused any problems or has proven to be a safe short-term option? Cheers
Normally the generics I see are not that great which is why they are probably on the dyno due to the owner being suspect, most appear to be quite lean in the top end because they exceed what the injectors are capable of, but there are plenty of people out there with generics that have had no issues.
A bad initial tune, wheter generic or custom, can do damage that may show later on when things are pushed a little harder.
You would be wise to get your tuner to do a tune to get the car running and limit the power/revs until you can do it properly.
If you can't afford a correct tune now, how will you pay for an engine if things went wrong?
  On 10/08/2012 at 11:31 AM, TheOne said:
Thanks for the info & recommendation Impellor, I appreciate it.
No offense to Impellor(I'm sure hes researched it) but you've chosen the recommendation of someone that has said in this thread, that they themselves haven't run a generic. So what makes you feel that that is useful information? When everyone with experience is saying otherwise?
UONCRACK
  • Member For: 15y 3m 21d
He may not send a disclaimer but if your engine blows it will be your fault as you chose to do that.
  • Member For: 13y 4m 20d
UONCRACK
Where did I say I'd chosen his recommendation? I was thanking him for it. Most of the information here is useful to me, whether it's what I'd like to hear or not - that's why I started the thread.
It was only intended as a short-term thing while I was installing the parts, the purpose of the thread was to find out if it was a viable option or not. The plan isn't for things to go wrong (!!), but from what I've read so far it's looking like that can't be predicted. Probably looking like a custom tune is the only way to go! Thanks for all the advice, it's much appreciated.
