  • Member For: 16y 3m 19d
Make sure your get a ELM327 v1.4b (1.5 has not been released yet, and is a cheap imitation)
  • Member For: 13y 11m 13d
Barnesy: thanks mate, ive just bought one, paid a little more and got one from australia instead of hong kong, because im impatient :)
What program do you recommend? Theres soo many, im using an ipad and connecting through bluetooth as suggested?
All of you people have been a great help :) thanks allot
  • Member For: 15y 3m 22d
The earth will probably fix it as these vehicles need nice clean power to operate 100%. You get all kinds of random crap cropping up when something as simple as an earth isnt working well enough (kinda like Airbus aircraft, very tempremental about power).
  • Sucker
  • Moderating Team
  • Member For: 21y 15d
  On 07/08/2012 at 7:57 AM, bionicxr6t05 said:
More than likely will be the battery, speedo is the first thing to go when battery is on its way out. Will not have anything to do with the coils or tps
:spit:
Was going to suggest that when I first noticed this thread...but figured I'd leave it for you. But yeah :stupid: get the battery tested/swapped before you waste money on anything else.
Tab:
chizz for the tip, im gonna get the battery checked anyway, that would be very frustrating though seen as I bought the battery 6 months ago for $350, its a performace battery for my speaker system, but its putting out 1050 cranking amp when it was tested in my car. So im pretty sure its gonna be earthing or something more serious :/
  • Resident idiot.
  • Member For: 14y 7m 19d
Bingo!
Same problem in Adie's car, new battery and it's all good now.
  • Member For: 14y 6m 20d
Yea mate I had my ICC out for sound system install and the problem came up like a year later. Just push it back in hard to make sure its connected properly and ensure everything connected at the bottom is in properly.
The TPS will throw an error code which you should be able to pick up on your new device
  • Bronze Donating Members
  • Member For: 13y 9m 12d
Lol @ paulie, battery will also throw tps codes due to comms faults caused by voltge drop at the pcm, generally u codes related to force limited RPM (limp mode) and vehicle speed signal missing
Seeing as battery is in the boot incorrect wiring sizes/ length or bad earth will also cause voltage drop
Edited by bionicxr6t05
