  • Member For: 15y 6m 13d
they don't have the best name, genuine have always been the best option
  • Member For: 14y 6m 19d
Had the EXACT same issue with my BA XR6, but after a while I couldn't turn the car off otherwise wouldn't start back up (driving without a speedo in a city with speed cameras sucks).
For me there was 2 issues! TPS was gone (was throwing an error code when I took it to Ford). So got a second hand one for $60 and changed it myself. Then also the ICC wasn't connecting properly to the car so try push it in real tight and double check all the plugs underneath it in the tissue box holder (I think theres 4).
I know the tps doesn't sound right but could be part of the missfiring issue, not 100% sure.
Maybe give the ICC thing a go, if you have to pull it out and push it back in (just be careful to not bend any of the pins on the connector when doing so. See how this goes then maybe try your tps
Probably wouldn't waste your time at ford, they had the car 3 times and never once picked up the issue
  • Member For: 13y 11m 12d
ok thanks, ill still get my earths fixed up, I think it will help in general. And ill make sure I get genuine coils haha, and ill clean the abs sensor..... is there a picture of this anywhere? Or a tutorial as ill be honest I have no idea where/how and what that is (except from it being near one of the rear wheels haha) and what can I clean it with, will maf sensor cleaner work?
  • Moar Powar Babeh
  • Member For: 19y 7m 15d
there's on on each back wheel, you cant missing it. Follow the wires from under the rear seat where they exit the interior along the control blade and onto the rear upright. They are the only sensors on the rear uprights. Just clean them with a rag. They are magnetic and tend to collect a bit of crap
Bellato:
Ive had the ICC out (not disconnected though) to install amp and twin subs, twin usb ports and a new head unit, the only thing I can say about that is, it was done about a year ago, and the problems has just started now..... still could be a possibility though.
How would I know that the TPS has failed? I dont want to be replacing the tps sensor, coils, & installing earths haha. But I guess more possibilities is better than none, thanks for your help :)
  • Bronze Donating Members
  • Member For: 13y 9m 11d
More than likely will be the battery, speedo is the first thing to go when battery is on its way out. Will not have anything to do with the coils or tps
Edited by bionicxr6t05
  • Member For: 16y 3m 18d
Scan for error codes with your obd2 port and see what pops up, you should get a U1900
Thanks allot guys, over the weekend I will do as much as possible to see if I can fix the problem, I think ill check a few of the things mentioned before buying any new parts. its still going to be hard to know if its fixed or not straight away, seen as it only does it randomly. But ill let you know the outcome when I know its fixed.
My plan if anybody is interested haha;
1. Fix up earthing
2. Check battery & cabling (as its installed in the boot) DIY
3. Clean ABS Sensors
After that if theres still no joy;
1. Check/replace Throttle position sensor
2. Check/ replace coils
3. Check icc unit cables
4. If all else fails get ford/fraud to check for problems, and error codes as I have no idea how to do that.
Thanks for all your help
