JBFG Member 19 Member For: 14y 4d Gender: Male Posted 23/05/12 11:15 PM Share Posted 23/05/12 11:15 PM I've got boost, oil temp and air/fuel ratio..air/fuel I don't know what to run it off...? Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 3m 22d Gender: Male Location: Muswellbrook,NSW Posted 24/05/12 08:54 AM Share Posted 24/05/12 08:54 AM boost, tee offf the BOVoil temp will require sandwich plate for oil filterAFR , whire or grey wire of the O2 sensor , (takes about 30 secs for it to start working) so be paitentpower and lights from cig lighter Link to comment Share on other sites More sharing options...
Rancidpunx Brisbanes Resident Detailer Donating Members 950 Member For: 16y 1m 6d Gender: Male Location: In my Cabin Outside Brisbane. Posted 25/05/12 05:46 AM Share Posted 25/05/12 05:46 AM The AFR will depend on whether its Wideband or not. If its not, then its about as useful as a screen door on a submarine. If its wideband then you will need a new bung welded into the dump pipe with a new Wideband oxygen sensor. Then you will need a device that takes the sensors readings and converts them into useful data for your gauge. I have a this http://www.innovatemotorsports.com/products/lc1.php. real easy to use.The oil temp as mentioned will need a sandwich plate between the oil filter and block. I would hook the gauge and electrics up and then wait until you drop the oil and then install the plate.Boost is easy.As for the electrics I have run everything off of the ciggy lighter as its only active with the key in the ignition and turned to Accessory. I also put plugs on all the gauge wiring so they can be removed without having to cut all the electrics again. If you want light on only with the headlights ON then you will need to cut a wire in the ICC harness although im not sure which one as there are many to choose from. Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 3m 22d Gender: Male Location: Muswellbrook,NSW Posted 25/05/12 06:22 AM Share Posted 25/05/12 06:22 AM narrow afrs are ok for seeing whats happening , just not how much.IF it is the wideband kit , the gauge comes with sensor, bung and all you need. u dont need another sensor , or interface kit , just the bung welded in Link to comment Share on other sites More sharing options...
JBFG Member 19 Member For: 14y 4d Gender: Male Posted 25/05/12 08:51 AM Share Posted 25/05/12 08:51 AM ok thanks heaps guys!! Link to comment Share on other sites More sharing options...
Rancidpunx Brisbanes Resident Detailer Donating Members 950 Member For: 16y 1m 6d Gender: Male Location: In my Cabin Outside Brisbane. Posted 25/05/12 08:53 AM Share Posted 25/05/12 08:53 AM Ah that's all right, I had to buy everything for my WB AFR separate. Link to comment Share on other sites More sharing options...
JBFG Member 19 Member For: 14y 4d Gender: Male Posted 25/05/12 10:31 AM Share Posted 25/05/12 10:31 AM Just seems like a sh!t of a job that's all haha. Link to comment Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 6m 6d Gender: Male Location: Melbourne, VIC Posted 25/05/12 12:35 PM Share Posted 25/05/12 12:35 PM My gauge/s are connected to my traction control light.. Anyone know why that would be?My gauges light up white when the car is on and when I turn the parkers or headlight on, they change to blue, is it because of this? If so is there another place to tap into to get the same effect?I have just got my window switches illuminated with LED's and I think they are messing with the gauge, as it stays blue all the time and my boost gauge isn't working, it lights up normally though. that's the only that has changed so I'm leaning towards it. I haven't taken out the window switches to see if it fixes the gauge but ill do that tomorrow. Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 3m 22d Gender: Male Location: Muswellbrook,NSW Posted 25/05/12 01:17 PM Share Posted 25/05/12 01:17 PM Trac light would be for illumination. Just wire them to the cig lighter and light them all the timeThe illumination system ford use is backwardsPositive is 12 v all the tImeEarth floats Depending on brightness settings Most after market gauges use pos to vary brightness and being led polarity comes into playIf its hooked to trac control. Earth will not be earth Link to comment Share on other sites More sharing options...
cruze Member 91 Member For: 17y 7m 10d Gender: Male Location: Northshore N.S.W Posted 07/06/12 03:09 AM Share Posted 07/06/12 03:09 AM Im using a bluetooth OBDII adaptor linked to my phone & tablet using "Torque" love it !! Link to comment Share on other sites More sharing options...
