Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 11m 29d Gender: Male Location: Perth Posted 16/05/11 05:22 AM Share Posted 16/05/11 05:22 AM That scan gauge looks really helpful. Looks like a way better choice then a wideband af gauge. Thx for that mate.I'd rather know what my AFR's are doing underboost than airtemp/trans temp/Coolant TempIm running an Autometer Pro-Comp Mech Boost and a techedge LA-1 AFR gauge driven by a 2J1 Wideband contoller/driver. This also feeds a WB02 signal into my HPT MVPI that I data log from. Link to comment Share on other sites More sharing options...
Bigkeels Throbbing Member Donating Members 594 Member For: 15y 7m 16d Gender: Male Location: Victoria Posted 16/05/11 08:05 AM Share Posted 16/05/11 08:05 AM Autometer Cobalt A/FWhat are they like? Whats needed to install one? Where abouts does the oxy sensor go? I've just always been told they are always all over the shop and not very accurate at all... Maybe they were cheapies..? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 11m 29d Gender: Male Location: Perth Posted 16/05/11 09:25 AM Share Posted 16/05/11 09:25 AM The gauge you linked to is a wideband afr and reportedly very good. Narrow band gauges are useless. You´d need to get a bung installed to install the sensor Link to comment Share on other sites More sharing options...
xr6turboman Donating Members 588 Member For: 16y 5m 9d Gender: Male Location: New Zealand, Palmerston North Posted 17/05/11 12:11 AM Share Posted 17/05/11 12:11 AM I've got a narrow band AF gauge and its actually very very annoying flashes backward and forward all the time lol..this bung you speak off what does this do and how much??ALso is anyone running those kiwi plx iphone gauge thing?? they look pretty interesting and kinda cool anymore info would be awesome..p.s sorry to hijack lol Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 11m 29d Gender: Male Location: Perth Posted 17/05/11 12:33 AM Share Posted 17/05/11 12:33 AM The bung has an M18x1.5mm thread to suit the 02 sensor. They cost about $4.... You just need to get a exhaust shop to weld in it (in the dump before the cat at least 300mm from the turbine outlet is the best combo for accuracy and sensor life. you can go closer to the turbin but the sensor wont last as long) Its very important that the sensor is mounted at leat 15 deg above horizontal so any condensation the builds up in the exhaust drain off and does cause the sensor heater element to crack/fail 1 Link to comment Share on other sites More sharing options...
Bigkeels Throbbing Member Donating Members 594 Member For: 15y 7m 16d Gender: Male Location: Victoria Posted 17/05/11 01:07 AM Share Posted 17/05/11 01:07 AM Awesome, so the bung on the nizpro dump would be ideal? Or does the factory oxy sensor go in there?Then it would just need power to the gauge, so it shouldn't be to hard to wire up. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 11m 29d Gender: Male Location: Perth Posted 17/05/11 01:21 AM Share Posted 17/05/11 01:21 AM It would be ideal, except the Pcm needs the factory sensor installed there I actually have mine installed there and my factory one slightly further down stream. If the sensor are closer than around 100mm apart its important to have installed so one sensor doesnt "block" the other or cause any swirlling in the gas that could affect the accuracytheoretically the longer distance to the sensor could affect the transport delay (the time it takes for the gas to reach the sensor after the exhaust valve opens.) which could potentially affect the PCM's cylinder afr trimming but just about every aftermarket dump puts the sensor in a different spot and I dont think another 100mm is going to make much difference at the speed the gas travels at! Link to comment Share on other sites More sharing options...
WhiteXR Member 117 Member For: 13y 11m 10d Gender: Male Location: sydney Posted 17/05/11 04:31 AM Share Posted 17/05/11 04:31 AM Can I ask, with the aeroforce obd2 gauge, can it read gearbox temp off the bat, or do you need to buy a special sensor for it to read the temperature?Thanks. Link to comment Share on other sites More sharing options...
Bigkeels Throbbing Member Donating Members 594 Member For: 15y 7m 16d Gender: Male Location: Victoria Posted 17/05/11 05:11 AM Share Posted 17/05/11 05:11 AM I know in a zf6 auto its there straight away. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 11m 29d Gender: Male Location: Perth Posted 17/05/11 05:19 AM Share Posted 17/05/11 05:19 AM BTR should be the same. Both PCM's use trans temp to alter trans functions so they PCM needs to know temp Link to comment Share on other sites More sharing options...
